Get some 4.10's and a 10" 3000 stall and some sticky tires. It will go like hell.
Do no use a stock GM differential in th stock GM rear end. Get a Eaton or a Auburn posi
and install it correctly. Get some traction bars. Easy 12sec performance from this simple build.
Get the compression ratio correct. You want a true measured 10:1.
