Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time porting heads
  #43 (permalink)
Old 01-06-2013, 12:48 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
If you want more performance than this. Drop the compression ratio by installing -15cc to -22cc dished pistons
and install a Weiand 142 blower complete kit for vortec heads.
Easy 11's. 7psi boost. use the cam you got or swap to a comp 12-404-4 cam CS268AH-14
Replace the stock springs with Lunati 73943 springs minus the inner damper.
Bolt on all stock rockers etc.
