Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time porting heads
  #51 (permalink)
Old 01-06-2013, 01:09 AM
Camaro_Nut2001's Avatar
Camaro_Nut2001 Camaro_Nut2001 is offline
Drag Racing Lover
Last journal entry: '68 Impala Project
Originally Posted by F-BIRD'88 View Post
If you are using any of the common stock diameter high perf valve springs you remove the inner damper
to go on a stock vortec head. EG lunati 73943. Some people use the GM LS-6 springs and comp 787-16 retainers on these heads.
With this 1103 camshaft the stock GM vortec head springs are fine. You need nto get all carried away
with valve spring pressure at all for this mild cam. You do not need to rev the **** out of the combo with this cam. 5000-5500 rpm is plenty. Its all about torque.
You got that right, it is all about torque, with me anyway. I have already cut the guides down so do I still run the Vortec springs without a locator or run the Summit springs without the damper?
