Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time porting heads
  #59 (permalink)
Old 01-08-2013, 02:18 AM
Camaro_Nut2001's Avatar
Camaro_Nut2001 Camaro_Nut2001 is offline
Drag Racing Lover
Last journal entry: '68 Impala Project
Originally Posted by cdminter59 View Post
This fel-pro .015 thick gasket wiil set you quench at .041 by your .026 measurement. Fel-Pro Performance Head Gaskets Q1094 - SummitRacing.com. Your static compression would be 10.248 and the DCR 8.295.
So if this were your build this is the gasket you would go with? I have a few old cam cards that are out in the garage that I plan on bringin in tomorrow so I can practice on this DCR figuring. Thank you for the link cdminter.
