First time porting heads - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 01-06-2013, 12:56 AM
Camaro_Nut2001's Avatar
Drag Racing Lover
Last journal entry: '68 Impala Project
Originally Posted by F-BIRD'88 View Post
That is a "towing converter" not a high perf converter.
Yep I know. I want a pretty long life out of this trans/motor combo so i'm not gonna be doin alot of Hot Roddin, but do want it to come alive when I ask it to. Do I need to remove the damper in the Summit springs for this cam?
  #47 (permalink)
Old 01-06-2013, 12:58 AM
F-BIRD'88's Avatar
Yada Yada Yada
Yes the 3000 stall is fie and exactly what you want.
When I drag raced this exact engine combo I shifted at 5000 rpm.
I used a 10" 3600 stall and 4.10's street strip drive it everywhere.
Get sticky tires so you have traction. M/T or BFG stickys. P235-60-15 4.10 gears
if you want to fab. make your own Caltracs.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
Camaro_Nut2001 (01-06-2013)
  #48 (permalink)
Old 01-06-2013, 01:01 AM
Drag Racing Lover
use the B&M holeshot 3000 converter or the Hughs -30 converter. 10" 3000 stall rated.
These are very street friendly high stall converters.
The towing converter is a very tight low stall for a very heavy truck and dedicated low rpm hiweay towing.
Its the wrong torque converter for a mild perf S-10 / 350 vortec combo.
Thanks for the heads up, changin converters. I like a Hughes a little more than a B&M when it comes to converters. The last S10 I built I ran a Hughes 3500 and it seemed a little much for the street but it was a play toy and not a daily driver.
  #49 (permalink)
Old 01-06-2013, 01:06 AM
F-BIRD'88's Avatar
Yada Yada Yada
If you are using any of the common stock diameter high perf valve springs you remove the inner damper
to go on a stock vortec head. EG lunati 73943. Some people use the GM LS-6 springs and comp 787-16 retainers on these heads.
With this 1103 camshaft the stock GM vortec head springs are fine. You need nto get all carried away
with valve spring pressure at all for this mild cam. You do not need to rev the **** out of the combo with this cam. 5000-5500 rpm is plenty. Its all about torque.
  #50 (permalink)
Drag Racing Lover
Thats the exact size tire I ran on my last S10 and the size I have planned for this one, lol. I have a set of plans for Caltracs that a buddy of mine fabbed up for his 81' Camaro that I may go by on my S10.
  #51 (permalink)
Old 01-06-2013, 01:09 AM
Drag Racing Lover
You got that right, it is all about torque, with me anyway. I have already cut the guides down so do I still run the Vortec springs without a locator or run the Summit springs without the damper?
  #52 (permalink)
Old 01-06-2013, 01:11 AM
F-BIRD'88's Avatar
Yada Yada Yada
The only real difference is going the be the installed length of the link bar.
The caltac design is very effective.
  #53 (permalink)
Old 01-06-2013, 01:19 AM
F-BIRD'88's Avatar
Yada Yada Yada
If you did not machine the spring seat inner diameter then remove the inner damper.
  #54 (permalink)
Old 01-06-2013, 01:21 AM
Drag Racing Lover
I did machine it for the Summit springs so I have to run the damper or a locator right?
  #55 (permalink)
Old 01-07-2013, 09:43 PM
Cars, Trucks, Boats
.. Your setup should HP peak around 5500-5700 RPMs, shift around 6000 or so...
.. 275-60R15 rear tires should fit under there...
.. Porting the intake ports is most important... you only have a max of 14.7 psi pushing air into the intake ports of a N/A engine... several hundred psi pushing it out the exhaust... Comp cams claims you can reduce exhaust valve lift by 2/3's with little effect on performance...
.. The exception, of course, would be engines with really horrible exhaust ports to start with... I've had to remove the air reactor boss from the ports of a '77 351W engine, it blocks about 80% of the port which was small to begin with... it wasn't even used on the marine engine I was building up... Ford should have sold Mercruiser engines without them... I don't think Mercruiser even realized the bosses were in there, since they didn't change the HP rating after the engines started coming through with the blocked ports... Mercruiser switched to Chevy engines the next year...
The Following User Says Thank You to BuzzLOL For This Useful Post:
Camaro_Nut2001 (01-07-2013)
  #56 (permalink)
Old 01-08-2013, 01:32 AM
Drag Racing Lover
Ok, I finished one head and got the other one apart and measured my quench this afternoon after my doctors app. I came up with 0.0260 in the hole. I'm running a 4 valve relief flat top that i'm guessing is around +6 vol. and the Vortec heads at 64cc. Like I said earlier, i'm running the Summit K1103 cam-Advertised Duration 272/282, Lift .442/.465 on a 112lsa. The way I figured it, keep in mind i'm still learning on DCR and SCR, I need to run a .028 head gasket. Am I on the right track? If so what do ya'll think about this gasket- Chevrolet Performance Head Gaskets 14096405 - SummitRacing.com ? Is there a better gasket both quality and price? If i'm completely off base lol, what gasket do I need to run with my setup? I'm shootin for as close to 10.1cr as I can get. Thanks.
  #57 (permalink)
Old 01-08-2013, 02:07 AM
This fel-pro .015 thick gasket wiil set you quench at .041 by your .026 measurement. Fel-Pro Performance Head Gaskets Q1094 - SummitRacing.com. Your static compression would be 10.248 and the DCR 8.295.
The Following User Says Thank You to cdminter59 For This Useful Post:
Camaro_Nut2001 (01-08-2013)
  #58 (permalink)
Old 01-08-2013, 02:10 AM
Drag Racing Lover
Sorry, I forgot to add that the head gaskets that came in my gasket kit, Sealed Power Gasket Sets Z2601000 - SummitRacing.com , are .039 compressed thickness which, once again if i'm figuring this right, would put my motor at 9.94.1cr.
  #59 (permalink)
Old 01-08-2013, 02:18 AM
Drag Racing Lover
So if this were your build this is the gasket you would go with? I have a few old cam cards that are out in the garage that I plan on bringin in tomorrow so I can practice on this DCR figuring. Thank you for the link cdminter.
  #60 (permalink)
Old 01-08-2013, 02:23 AM
Drag Racing Lover
How did you figure that? I'm coming up with 10.53.1, lol. What did you put in for Deck Clearance?
First time Head Porting. How am I doing? zildjian4life218 Engine 17 02-02-2010 06:28 PM
Porting intake manifolds, is it a waste of time? Mad Maggot Engine 25 01-06-2005 11:59 PM
This has to do with porting my own heads..... Rubberman2003 Engine 2 01-25-2003 08:32 PM
Porting heads MHenricks Engine 11 09-05-2002 07:55 PM
porting heads oldsnut Engine 9 01-30-2002 08:41 AM
