First time porting heads - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 01-08-2013, 03:53 AM
Cars, Trucks, Boats
.. I get 10.24:1 static using 6cc pistons, .015 gasket, .026 deck, 4.030 bore, 3.48 stroke, 64cc heads, 8 cylinders(for cubic inches/L.) using Summit's compression ratio calculator. Lower C.R. if pistons have sizable champfer on top outer edge...
.. I would definitely use the thinner gasket for better quench effects/benefits and power... despite slightly higher compression ratio...
Compression Calculator - SummitRacing.com
The Following User Says Thank You to BuzzLOL For This Useful Post:
Camaro_Nut2001 (01-08-2013)
  #62 (permalink)
Old 01-08-2013, 04:14 AM
Camaro_Nut2001's Avatar
Drag Racing Lover
Last journal entry: '68 Impala Project
This is a stock 4.00 bore motor and I just ordered the gaskets, lol.
  #63 (permalink)
Old 01-08-2013, 10:09 AM
I used this website's calculator. United Engine & Machine Co. Incorporated Cylinder Head Volume: 64cc Piston Head Volume: 6 Gasket Thickness: .015 Gasket Bore: 4.100 Cylinder Bore: 4.030 Deck Clearance: .026 Stroke: 3.4800 Rod Length: 5.7 Intake Valve Closing: 63 (DO NOT ADD 15) (Use valve timing @ 6*) Here is an easy formula to get intake valve closing point. Advertised intake duration / 2 = ?, ? + LSA = sum, Sum - (LSA - ICL) = ?, ? - 180* = Intake closing point 272 / 2 = 136, 136 + 112 = 248, 248 - (112 - 107) = 243, 243 - 180* = 63
The Following User Says Thank You to cdminter59 For This Useful Post:
  #64 (permalink)
Old 01-08-2013, 10:20 AM
1Gary's Avatar
Last journal entry: Ole Yellar build-1989 383 SBC Astro build
Remember.To smooth port the runners in Vortec heads destroys the "Vortec effect" which is there as part of their design which suspends the A/F mixture.The exhaust side on the other hand will benefit from porting.
The Following User Says Thank You to 1Gary For This Useful Post:
  #65 (permalink)
Old 01-08-2013, 10:24 AM
How fast is fast enough?
Who sold you that line of crap? The vortec heads perform as well as they do thanks to a tall runner, better short turn, and better chamber- it doesn't have a damn thing to do with surface finish.
  #66 (permalink)
Old 01-08-2013, 10:28 AM
Drag Racing Lover
Thank you!!!
  #67 (permalink)
Old 01-08-2013, 10:37 AM
valve timing at 6*
Just a small technicality- .006" NOT 6º.
And be careful with this number as advertised duration may or may not be at 6º even for a given cam grinder they're adv duration specs can be measured at different points .004", .005", .006" are all common for hydraulic cams. For solids the lash value is sometimes used, sometimes its .004" and sometimes its .020".
The Following User Says Thank You to ap72 For This Useful Post:
  #68 (permalink)
Old 01-08-2013, 11:04 AM
1Gary's Avatar
While I look for the ref to your question,I found this info that might be useful to the O/P:
Porting For Performance The Science of Horsepower: Engine Builder
Off hand I think it was Larry Carley or Joe Mondello,but I got to find it.You see at the bottom of this ref,Joe talking about a different finish on the intake side.But Joe has been dead I think for two yrs now,so I might not find the ref I want.I used to talk to him often too yrs ago.
The Following 2 Users Say Thank You to 1Gary For This Useful Post:
Camaro_Nut2001 (01-08-2013), techinspector1 (01-08-2013)
  #69 (permalink)
Old 01-08-2013, 11:15 AM
Drag Racing Lover
Thank you for the usefull link as i'm gettin ready to start porting my other head the same as the first one but i'm hopefully gonna build a pretty stout, 475-525 pounds of torque, 400 block i've got for my next build and plan on really working the heads for it. I have a pair of Patriots for it but not sure yet if i'm gonna use them or not.
  #70 (permalink)
Old 01-08-2013, 11:24 AM
1Gary's Avatar
Patriot went out of business,so if you have a good set,you might want to baby them.I was told they where bought out and was going to reopen in acouple of months under another name,but I didn't get who bought them or what the new name was.
  #71 (permalink)
Old 01-08-2013, 12:25 PM
a different finish being a 80grit cartridge roll. even the finish a carbide bit leaves is must smoother than a rough casting, especially a GM casting. going over it with 80grit helps smooth the high and low spots, its not needed but sometimes it helps. I like to spray the port with dye right before I'm done and then take a used 80grit roll to it, the low spots show up immediately.
  #72 (permalink)
Old 01-08-2013, 01:52 PM
1Gary's Avatar
I am very sure by a reliable source the Vortec heads rough surface plays a role in the performance of the heads by suspending the A/F mixture.That you can benefit from porting the exhaust side,but not to alter the intake runner.That if you smooth port the intake runner,what your left with is just another set of OEM castings.
It is one of those deals that is a summary in your knowledge base you have learned along the way.
  #73 (permalink)
Old 01-08-2013, 02:16 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Great article Gary, should be required reading for all of us....Joe explains the proper grit to use in the last paragraph of the article.
  #74 (permalink)
Old 01-08-2013, 02:57 PM
Cars, Trucks, Boats
.. Obviously there is benefit in altering the intake port... that's why heads have gone from the older 157cc intake ports to 175cc and 185cc Vortec intake ports and 195cc AFR's and 235cc MoTowns, etc...
  #75 (permalink)
Old 01-08-2013, 03:20 PM
To say any port is optimized as cast is a bunch of stinky BS. Just as any other head they can be improved upon by porting the intake and exhaust, in the case of the oem production vortec heads they can be improved a great deal.
First time Head Porting. How am I doing? zildjian4life218 Engine 17 02-02-2010 06:28 PM
Porting intake manifolds, is it a waste of time? Mad Maggot Engine 25 01-06-2005 11:59 PM
This has to do with porting my own heads..... Rubberman2003 Engine 2 01-25-2003 08:32 PM
Porting heads MHenricks Engine 11 09-05-2002 07:55 PM
porting heads oldsnut Engine 9 01-30-2002 08:41 AM
