First time rebuilding T-350 questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2008, 12:56 PM
Absolute beginner
Hello to everyone here :-)
I am rebuilding my TH350 and it is my first transmission I repair ever
I followed three books to disassemble it (Haynes, ATSG and Ron Sessions), no problem so far ... until i got to the valve body ... I removed all valves but manual low control valve the retaining pin does not move at all ... the plug is moving in and out freely. See picture.
I would appreciate your help on showing me how to remove it.
Also, I read that TH350 should be filled with Dexron II. Unfortunately I can find only Dexron III here, I am from Bulgaria and automatic transmissions are relatively rare :-)
Thank you very much,
Ivo
Old 09-07-2008, 02:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF you have compressed air ... use an air gun and push on the plug while blowing air at the end of the pin.
No compressed air? Turn the v-body upside down... bang the v-body "lightly" on the work table while pushing in & out on the plug to force the pin to fall out.
Dexron II or III are the same basic fluid. It all works fine.
Old 09-07-2008, 02:24 PM
Absolute beginner
Hi Crosley,
Thank you for your fast reply.
I have compressed air :-) I will try it.
I tried the other way you described with no luck even with not so "light" bangs
I also used some cooling spray (should release stacked bolts and nuts), it comes out around the pin but it does not move at all.
Thank you,
Ivo
Old 09-09-2008, 12:02 PM
Absolute beginner
It is out
Crosley, thank you for the help the compressed air worked out
I have another question.
I have 1 liter of Dexron II, I plan to use it to soak parts in it.
Then I will fill the transmission with Dexron III.
Do you think it would cause any problem?
Also, how long the transmission could stay assembled but not filled up?
I have to wait or some parts to arrive one or two weeks...
Thank you,
Ivaylo
Old 09-09-2008, 12:29 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Dexron II and Dexron III will mix without issue. The III superceedes the II and will work in all applications requiring I, II, or III.
Old 09-11-2008, 12:11 PM
Why not use the latest fluid which is DEXRON VI? This fluid is much improved compared to DEXRON III.
Old 09-15-2008, 11:36 AM
Absolute beginner
Hi The Factory Man,
Thanks for advice, but I found Mobil ATF220 (Dexron II) at very reasonable price some $7,50 per liter
Does anyone know for sure how many liters TH350 would take to be full?
I read it should get about 10 liters. Is it correct?
Thanks,
Ivo
Old 09-15-2008, 12:16 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
10 1/2 qts/liters that's including the stock torque converter + your cooler.
Rich
Old 09-20-2008, 11:02 AM
Absolute beginner
Hi guys,
Thanks Rich.
I got my rebuild kit but some of the clutches, tow actually, got some dents during the shipping see pictures.
Can I use them or I have to order new clutches?
Also, I am in Bulgaria, so clutches are not widely available and I have to order them from USA can I use two of my old clutches as last resort?
Thank you,
Ivo
ID:	32592   Click image for larger version
Old 09-20-2008, 09:08 PM
Cape Cod Bob's Avatar
Keep us posted. I did my first one last year and am waiting to finish the rest of the car to to see if it works. The only real problem I had was with the anti clunk. The book I had did not have a good picture. But someone on here posted one for me.
Old 09-21-2008, 12:03 AM
Ivo,
I wouldn't use those clutches because I believe they will continue to deteriorate & cause a problem.
How do the old clutches compare to the good new ones? you can
use them, but I myself don't like doing the same job twice,
does it take a long time to get parts from over here?
Rich
Old 09-21-2008, 01:23 AM
SSedan64's Avatar
Rich is right. Trans Shops do it all the time. Some prefer good used/seasoned clutches & bands as long as they're in good shape. If they're dark/discolored from overheating or severely worn don't reuse them.
Old 09-21-2008, 06:29 AM
Absolute beginner
Hi guys,
Thank you Rich and SSedan64 for your valuable replays.
I checked the old ones, and I think they are not usable. See pics.
Also, the TH350 was burnt (may be by me ) as I did not know anything about automatic transmissions before.
The car was not driven for at least 10 years and when I start it I made some 10 km and it stopped running forward.
When I open the transmissions the Forward clutch pack was burned.
I am going to order new clutches, It takes some 15-20 days to get them.
Thanks again,
Ivo
ID:	32614   Click image for larger version
Old 09-21-2008, 11:25 AM
Ivo,
Those clutches aren't reusable.
while you have this apart be sure to flush the lines, torque converter, & cooler.
it only takes a minute piece of dirt to cause a problem. especially in the valve body & TV valve.
As for the ATF Mobile 1 synthetic is for all GM transmissions
from 2005 back.
Rich
Old 09-22-2008, 06:59 AM
Absolute beginner
Hello Rich,
Thank you for your help, I hope everything will go well
I have new (rebuild) torque converter, I will not use the old one. I am taking apart everything and deep it in solvent.
I noticed something strange though...
The transmission has got only four friction plates in forward and low-reverse, but the books I have (Haynes, Ron Sessions and ATSG) said there should be five. Also the rebuild kit I bought contains five of each.
Should I install four frictions as it was or should I follow the books directions?
Thank you,
Ivo
350 TBI first time rebuilding engine...question Jaykobo Engine 16 01-16-2013 02:06 PM
1st time rebuilding a 90 model 700R4 tranny Johnnyasa Transmission - Rearend 1 06-28-2011 07:50 PM
First Time Rebuilding Woes Dino383 Transmission - Rearend 2 11-15-2010 07:45 PM
rebuilding heads(its my first time,be gentle) ratrod47 Engine 2 07-26-2009 06:39 AM
Two questions on rebuilding Dbodily Engine 2 02-18-2004 02:18 PM
