Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time setting up rear end.
Old 01-18-2013, 08:18 PM
slownugly slownugly is offline
Ok sounds good! I will mess with it and see what I can come up with. Ill post back and let you know what I find out. Thanks for the quick response!
Right now my carrier is pretty snug and with just the carrier in place it has drag and can spin almost one full turn. To get it out I have to use a pry bar and cant get it out by hand alone, so I believe my shims are good? At least for set up, I may add .005" to each side to preload them on final assembly?
