Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time setting up rear end.
Old 01-19-2013, 08:27 AM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
If you can get the backlash to .010 we will see what the pattern looks like. You may need to go back a little on the pinion shim if the drive pattern doesn't look better. If you could take the pinion shim to .037 it might help. I've got a few thousand shims, so making small adjustments is no problem for me. For the guy who only has about 10 shims from one installation kit it's a little harder.
