Looks like the pinion needs to go a little deeper. Try adding about .003 to the pinion shim.
Use an axle to turn everything when checking the pattern. Be sure that you have the pinion bearing preload set correctly each time you check it. If you are not consistant with the bearing preload then the pattern changes will be confusing. Add a drop of oil to the marking compound to thin it slightly and make several revolutions with the ring gear in both directions to wipe away the compound enough to make the pattern clear and easy to read. |
| The Following User Says Thank You to big gear head For This Useful Post: | ||
Crosley (05-10-2013) | ||
Thanks guys!
Gear head I went with your suggestions and Im now running a .035" shim under my pinion with .010" backlash (on the first pattern I posted I had a .032" shim and .012 backlash) This is the pattern I have now (pictured below: 1st pic-drive pattern, 2nd pic-coast) Thanks again! |
Yes, that is better. Look at the drive pattern in the first post. Notice that it favors the face of the tooth and the root is curved and not as long as the face. In the second set the pattern is about equal at the face and root of the tooth, which is what you are looking for. Many people get hung up on heel to toe, when root to face is what is most important. You probably will not be able to move this pattern off of the toe, so I wouldn't worry about that. Notice that your coast pattern is still favoring the face a little. You might try adding about .002 to .003 more to the pinion shim and see if it moves the coast side closer to the root without messing up the drive side.
Thanks again gear head!!
Here is the set up with .038" shim under pinion, .008" backlash and between 15-20 in/lbs of preload on the pinion nut. Let me know what you think. drive pattern-1st pic, coast-2nd pic |
The coast side looks much better, but the drive side looked a little better before. Try increasing the backlash by about .002 and see what happens to the drive side.
Ok will do! Im gonna take .005 off of one side and add it to the other to increase the backlash and see what that looks like. Ill post the pictures when I get the pattern. Thanks for all your help! Ive heard that reading a pattern correctly is more of an art than a science, so it has helped having someone who knows what to look for. Thanks bud!
Gear head,
I was only able to adjust the backlash in .005" increments since thats what shims came with my richmond kit. I adjusted the pinion shim to .038" and adjusted the carrier by .005" and the backlash ended up at .012". Personally, Id like to stay at .010" or lower, but not sure if the allowance works both ways. Ive found through research that .008"-.010" (.010 is stamped on my gears) is where you want to run it, so not sure if .012" would fly? If I went up to .040" would this tighten up the backlash if I left the carrier shims the way they are? Or should I just run with the .035" pinion shim and take everything back to the way I had it in my second pattern I posted? |
The pattern is probably better with the .038 shim. If you can get the backlash to .010 it would move the drive pattern a little more to the heel and possibly make it look right. Increasing the backlash moves the pattern toward the heel. Closing the backlash moves the pattern toward the toe. Increasing the pinion shim moves the pattern toward the root and taking shim out of the pinion moves the pattern toward the face. Don't try to make up for backlash by changing the pinion depth.
If you can add some shim to the right side without taking anything out of the left side it might move the backlash .002. Do you have the shims tight enough that youc an not pull the differential out by hand? If you can't get the backlash to .010 then stay with .008 and .038 pinion shim. |
Ok sounds good! I will mess with it and see what I can come up with. Ill post back and let you know what I find out. Thanks for the quick response!
Right now my carrier is pretty snug and with just the carrier in place it has drag and can spin almost one full turn. To get it out I have to use a pry bar and cant get it out by hand alone, so I believe my shims are good? At least for set up, I may add .005" to each side to preload them on final assembly? |
I wouldn't try adding .005 to each side if it's already that tight. You will probably damage your shims if you try that. Maybe just try adding .005 to the right side to open up the backlash just a little.
I know that this is a little late, but if you decide to do another gear sometime don't get a Richmond installation kit, or a Ratech kit or anything else that Jeg's or Summit sell. The kits that DTS, Tom's Differentials and Randy's Ring & Pinion sell have the super shim sets in them. You can make much more accurate backlash adjustments with these, and they are much easier to use. The shims in the other kits are just not good enough. |
Yea, I thought that this kit would come with the adjustable shim stacks that adjust by smaller increments but it didnt and another lesson is learned!
I will still try to add a little to the right side to open the .008 to .010 and see what it reads. So do you think the .038 pinion shim is the more ideal pattern if i can get the backlash squared away? Thanks gear head! |
If you can get the backlash to .010 we will see what the pattern looks like. You may need to go back a little on the pinion shim if the drive pattern doesn't look better. If you could take the pinion shim to .037 it might help. I've got a few thousand shims, so making small adjustments is no problem for me. For the guy who only has about 10 shims from one installation kit it's a little harder.
I was able to get the backlash to .009" by adding a .005" shim to the right side carrier. My pinion shim measures .038" and this is the pattern I was able to obtain. Let me know what you think?
This looks way better than my very first pattern that I started with and its been awesome adjusting it and being able to see how the pattern changes. Im glad I didnt call it good enough with the original!? |
| need help setting mechanical advance(my first time) | xzero117 | Hotrodding Basics | 1 | 10-04-2012 12:42 PM |
| setting up a 4baron a 9in ford rear end in a 32 fo | show off | Suspension - Brakes - Steering | 3 | 03-03-2012 12:43 PM |
| first time rear-end rebuild | biscuitville | Transmission - Rearend | 4 | 02-24-2010 09:12 PM |
| Ford 9" rear end vs stock 89 chevy truck rear end | jimmy p | Transmission - Rearend | 2 | 12-07-2005 03:28 AM |
| Tranny + Rear End going out at same time? | 94silverado4x4 | Transmission - Rearend | 3 | 03-31-2004 03:38 PM |
