First time shooing a HVLP gun and paint came out splotchy. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2010, 09:56 PM
To extrapolate a bit: I am using a 1.5 tip on a hvlp shooting primer-surfacer. I mixed the primer exactly the way it directions said to do. It was 65degrees out and I mixed 4 part pimer/ 1 part hardener 10% cutting agent. It was the first time using the gun (it's a cambell hausfeild) and was shooting a board with the pressure regulator on the compressor at 50psi and then dialed in the gun with a regulator on the end at 10PSI ( the gun says on the tip max 10 psi). I then shot the paint but it came out in big drops, not a fine mist. I figured there was not enough cutting agent so I put another 10% cutting agent in and it came out a bit better but still splotchy. (then shot with both a regulator on the base of the gun and with the regulator off the gun and the regulator on the compressor at 10psi.)
Is the problem the tip or is the primer not cut enough? I've read you can cut it more and it just takes longer to dry.
The primer is brand Newstar ns-700. I had previously tried to look around to buy a 2.0 tip but could not find one? Is there a place to get just a tip for my gun?
One more thing. This was my first time using the gun and it was used. I tried taking it apart before I used it to clean it (although it looked imaculate) but could not get the part of the gun behind the tip to come off. It does unscrew --lefty-loosy-- right? I would imagine so.
Need all the help I can get. any replies appreciated. thanks
UPDATE
The general consensus is that I didn't have enough pressure to the gun. I'm going to try again today but a followup question for everyone.
I did go ahead and spray my trunk last night with the sprayer sprayin like it was. It was over bare metal and very thick instead of a light coat like everyone says to spray the first time. Should I sand it all back down or just sand smooth and spray again?
Old 02-06-2010, 10:03 PM
deadbodyman's Avatar
Wiki Edits: 11
Did you try incressing the pressure at the tip?
Old 02-06-2010, 10:19 PM
i believe you are talking about the knob on the bottom of the gun. if so then yes.
Old 02-06-2010, 10:27 PM
Wiki Edits: 11
Try spraying straight thinner through it see if it works like that,then try incressing from 10lbs to 20lbs of pressure.does you fan control knob work?
Old 02-06-2010, 11:16 PM
ill try that. i couldnt really tell.
Old 02-07-2010, 12:44 AM
Sounds to me like you need more air pressure - what is the recommended inlet pressure of the gun?
The tip/ air cap may say 10PSI max (a HVLP standard), but you need to be giving the gun much more at the inlet to achieve that. Too low a pressure and the air cap simply won't be able to atomise properly, so it'll almost be throwing out lumps of primer, rather than a finely atomised spray.
Old 02-07-2010, 05:53 AM
302 Z28's Avatar
Your HVLP gun is internally regulated to 10 psi at the tip, that is NOT the inlet air pressure you set. Your inlet pressure needs to be at least 30-35 psi or higher depending on what your spraying.
Vince
Old 02-07-2010, 10:01 AM
Ok, I'll try more pressure today. Another question first though. I did spray my trunk yesterday. It was a very thick coat instead of a light coat like what is advised for a first primer coat. Should I sand it all down or sand smooth and spray over the primer?
Old 02-07-2010, 12:48 PM
302 Z28's Avatar
If it was excessivly thick I would allow several more days for cure then sand it smooth for another coat.
Vince
Old 02-07-2010, 01:04 PM
Or a slightly different option - give it a light sand now with something like a P240 or P320 just to break the surface to aid curing and help the solvents escape. Then after a few days carry on as above - sand then recoat.
Old 02-08-2010, 05:40 AM
Wiki Edits: 11
Are you planning on painting the trunk or using a rubberized undercoating (one that gets hard)? If your painting I"d use a 2k sealer instead of primer ,it'll eliminate the need for more sanding ,some sealers adhere to the bare metal (sand through spots) very well.If you started with an epoxy sealer from the start there would be no sanding at all,and its thinner so there wouldn't be a problem getting it out of the gun.
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 5 11-07-2011 07:14 AM
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
