I just did a set of ralley's and used epoxy, then primer, mine were as rough as yours...or worse... I think the feather fill will be too thick..and for rallys, all that needs to be really nice is the front and really not under the center cap as much, which means, on the front lip and center area that shows...you can lay a couple coats of primer ..either epoxy or 2k..and those areas will be easy to sand....
