Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time spraying PPG DP50 and Featherfill G2. Advice needed.
Old 02-19-2012, 03:20 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Just epoxy wont stop them from rusting again fairly quickly...What I would do is first wire wheel some Ospho in there ,theres still quite a bit of rust in those pits the Ospho will remove most of whats left and convert any remnents there might be,Then use the SPI epoxy ,it will build but it'll take mabee 5-6 coats...give it a good sanding and shoot it with 2 more coats ..that should do it ...
