If you turn the gun down so the trigger barely moves and not much paint comes out,almost none it's easy to get into all the cracks and hard to reach spots first and carefully once you get the whole thing covered you turn the gun up and put a nice wet coat on you won,t get runs. Also turn the fan closed so it hits small spot at first,then widen for wet coat to about six inces. If you need to fill the pits with the filler primer just turn down the amount again and carefully fill where you need it. Don,t be in a hurry and learn to adjust your gun and it is easy,and won,t get out of hand and cause extra work.
