Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - First time: valve train geometry/mock up questions
Old 08-20-2012, 06:36 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Silver Surfer View Post
Also, should I ditch the hydraulic lifters for this and use solid lifters so I do not have to worry about the plunger?
I wouldn't swap out to a solid cam and lifters unless you were going to use a more radical cam than the one you've chosen. It's also not a good idea to use the wrong type lifter on a cam (solid on a hydraulic for example), if that's what you were considering doing.
The Following User Says Thank You to cobalt327 For This Useful Post:
Silver Surfer (08-25-2012)
