First time welder with Millermatic 140 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-08-2011, 08:39 PM
Originally Posted by timothale
Martin Sr has written a very good guide to mig welding..
+1 on that! That has to be the best most thorough piece I have ever seen covering light MIG welding for thin sheet like body panels.
  #17 (permalink)
Old 11-08-2011, 08:44 PM
Originally Posted by mmopar0521
I ran a bottle out after a long couple of days welding on a weekend, and couldn't get a refill.
We discussed that a while back and most agree those dang bottles have a dump valve that is timed to automatically empty on Saturday afternoons!
J/JK of course but it sure seems to work that way.
  #18 (permalink)
Old 11-08-2011, 08:54 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Reminds me of buying spray paint with "pre-packaged" runs.
We've also noted that the probabilty of having a supplier or delivery screw-up is inversely proportianal to how bad you need it, squared by a factor of Friday.
  #19 (permalink)
Old 11-08-2011, 10:23 PM
dallas1's Avatar
this thread has bin a big help to me as i am trying to soak up all the info i can to learn what i am doing.
just want to say thank you to you all for all the good info.
if it was not for this i would have got a cheap flux core welder then bin cussing every time i blew a hole in the sheet steel.
  #20 (permalink)
Old 11-09-2011, 07:00 AM
Wiki Edits: 27
Martinsr weld info
I did a search here on HR for ( basics of basics Martinsr) And it brought up the article.
  #21 (permalink)
Old 11-09-2011, 07:08 AM
Wiki Edits: 27
buying used bottles.
welding bottles have to be tested and certified every so often. Those numbers are stamped on the bottle. My old portible 2 ft high ox acety set had not been used for about 15 years. when I needed to use them again and get a refill they were still good and the supplier traded for new ones. I had a friend that moved to the east and the moving co would not take the extra bottle he had in his garage. When I took it in they said it was too old, had lots of numbers stamped on it. They would not exchange for a full bottle. JUST BEWARE when buying used bottles, Make sure you can exchange them.
  #22 (permalink)
Old 11-09-2011, 07:21 AM
Age itself does not mean much and bottles from the 40's are common due to war production, I have seen test dates as far back 1917! Theses really old bottles have been relegated to CO2 service now but a welding supply in KY I used when working in that area had a bunch of them ranging from that old 1917 bottle to several dated 1919 and a few in the 20's. If a bottle is still in good shape, no apparent damage and it's not rusty, it only needs a recent test date. If it's out of date they can not fill it until it's tested so there is usually an extra fee when exchanging an out-of-date bottle
  #23 (permalink)
Old 11-09-2011, 07:28 AM
Wiki Edits: 27
rusty YES
That old bottle was rusty on the bottom. , probably why it was rejected.
  #24 (permalink)
Old 11-09-2011, 07:59 AM
You betcha, rust gets those guys excited in a hurry!
Part of the test is a visual inspection and if the inspector determines a bottle is physically damaged or rusty that's the end of it and the hydro test is not even done. Once they mark that bottle as "failed" it then becomes just another piece of junk.
  #25 (permalink)
Old 11-16-2011, 08:10 PM
Any welding supply store should be able to rent a bottle to you and you can just get a mini bottle for at home. I've been welding quite a bit with mine and still have half a tank. Use .030 wire for sheet metal applications. Your welding machine manual should have a matrix chart with wire feed speed(amps), and voltage for your wire/metal thickness that you are welding. The best gas for mig is a tri-mix. it is mostly Argon with a little CO2 and believe it or not a little O2. The manufacturer up here in Canada for this gas is Air Liquide and the gas is called Almig. When welding keep your wire stick out to a minimum(more bead control and less amps/heat), weld with a trailing motion( same as writing if you are right handed) left to right for flat welds to prevent burn through( you are depositing weld metal on weld metal rather than heating ahead of your molten puddle and burning through) and down hand for vertical seems. Also, to keep spatter down to a minimum try to keep your nozzle angle perpendicular to your workpiece. Use some scrap to experiment with the angle.
Also for filling gaps try "triggering it", pulling than releasing the trigger every second or so to allow the puddle to solidify in between pulls.
One other thing, if you are going to go with the argon gas mix(the best and not too $$), you may need to change the male fitting that goes into the bottle as it is different than a CO2 fitting. The regulator is the same, its just the end piece that screws into the bottle that you need to change. They are about 5$. A can of anti/spatter spray goes along way with saving your tips and also a quick coat on surrounding components helps with cleanup. I like the spray better than the gel for that reason.
A good starter project for a mig is a cart for it.
Cheers and good luck,
Joe Welder.
  #26 (permalink)
Old 11-16-2011, 08:43 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i would go to a com. college and take an evening weld class
and i would also go to the weld supply store and just talk them about your options from them to get gas
i would not buy a used bottle off the street
practice, practice, practice
  #27 (permalink)
Old 11-22-2011, 03:10 PM
Lost and out of my mind...
I have a MILLER MATIC 220 and works great, just take ur time and practice. Key is good penatration and work on ur beads next... There is a ton of diffrent way though, stich welding, tac. ect ect.. depending on what u are working on... Do not use flux core IMHO. its messy and looks like crap. I use a mix gas but see what works for you.. Good luck
PS Friends dont let friends burn with red...
Millermatic 200 Morgan22 Garage - Tools 4 09-02-2009 07:07 PM
millermatic 180 chase1994 Garage - Tools 7 06-19-2009 08:34 PM
New MIG welder time. crazy larry Garage - Tools 28 07-30-2005 11:57 AM
Millermatic DVI or 210 Hotrod20s Garage - Tools 3 01-20-2005 12:28 AM
Millermatic 175 302 Z28 General Rodding Tech 1 03-15-2004 07:48 PM
