fish eye - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2012, 01:52 PM
fish eye
Hello everyone. I am painting a fiberglass hood and only the clear has fisheyed. What is causing this?
Old 04-25-2012, 03:37 PM
Ifit aint fix...Don't broke it
Last journal entry: 52 fleetline firewall
fish eye
spraying oil before painting or water in air. penetrating fluid is the worst!
Old 04-25-2012, 03:55 PM
Thanks sir. I sprayed the car with same issue. So I didn't wet floor and it has done it again. I changed from my usual clear. I used omni mc270. I usually use transtar motor city clear. I have never had this issue.
Old 04-25-2012, 06:02 PM
dinger's Avatar
Are you sure it is fisheye and not solvent pop? They look a little alike, if there is a slew of it, it is probably solvent pop.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 04-25-2012, 08:49 PM
It looks like lil craters all over. So I'm not sure. But it made my work look like junk.
Old 04-26-2012, 09:20 AM
dinger's Avatar
Try color sanding the clear,then recoat. A longer wait between coats is needed with some of the clears. A lot of the guys use SPI, supposed to be the best.
Old 04-26-2012, 09:32 AM
I will try that. Thanks for the help.
fish-eye causes gto_ron Body - Exterior 8 03-24-2012 09:23 PM
Odd fish eye question...Need a bit of help 96p993 Body - Exterior 3 04-16-2011 06:40 PM
fish eye problem! xpsyclonex2002 Body - Exterior 31 05-25-2010 07:48 AM
Fish Eye/Orange Peel trucker831cali Body - Exterior 5 12-18-2009 06:11 PM
fish eye eliminator Tattoou Body - Exterior 6 08-18-2003 03:28 PM
