Ron,
Obviously oils of any kind are fish eye causers.... not just silicone based products. If you are spraying with air...I would suspect you might have a contaminated air line/hose....check and clean and dry your air separater from the compressor. Go buy a new air hose just for painting and not garage use. The diapers...umm I question that. Wipe alls are fairly cheap in all aspects of the job. They are available at all automotive paint suppliers. If your "eyes" are only in the clear coat... IT might be contaminated.... sorry...but it happens. Eyes are caused from something ON THE SURFACE, so after it is wiped there are very few ways for it to get there other than it being applied by the sprayer. Good Luck! |
"1. Are there other sources that aren't so obvious?
2. Will anything else cause fish-eyes?" fabric softeners hair-care products hand cleaners w/ lanolin certain perfumes actually the list is endless, it can be a nightmare to chase down. |
there is a way to check with water before paint to make sure you get all the wax and grease remover off...
http://youtu.be/1-UAmubknFw
Milo I love your style!
And that sounds like good advice, but I don't know how that would ever be practical on my car, I wouldn't want to be spraying that much water all over it... |
It sounds to me like you have the car nice and clean ..So if the panels are clean it would have to be coming from the compressoror or the lines...check and clean your filters then change the little disposable bulb filter at the gun...A toilet paper filter works wonders as a finel filter for getting water and oil ...
;;;;;;;''''''/////Did you drain the tank>>>>> |
How old is your activator? I had about a half quart that had been sitting on the shelf for about a year. I went on and used it and I was ate up with fish eyes and pop ups. From now on I will pour it in a smaller container or I won't use it, I thought I was going to save money but I doubled my work and still had to spend the money.
fish=eyes
thanks all!
I'll keep learning new things until I hang up the paint gun for the last time. Some of your suggestions rang true, I haven't changes my final water & particle remover filter in about a year plus my wife uses fabric softener in every laundry load. I have a dedicated paint hose with all 3/8 fittings and 3/8 ID but if my filter has failed it may be contaminated too. keep adding more tips, they are appreciated regards Ron |
"Some of your suggestions rang true, I haven't changes my final water & particle remover filter in about a year plus my wife uses fabric softener in every laundry load."
the paint store should have tyvek paper 'shot suits' that would eliminate that as an issue BUT if you wear it all day it can smell like a sweat sock.
| Was it the big fish that got away... | pigjamelectric | Hotrodders' Lounge | 5 | 12-16-2007 08:22 PM |
| about fish | fish | Introduce Yourself | 4 | 12-07-2007 08:50 PM |
| new fish | aceswild1 | Introduce Yourself | 2 | 09-24-2007 09:22 PM |
| anyone got fish? | bullheimer | Off-Topic | 12 | 01-31-2006 11:02 AM |
| New fish | jimpa | Hotrodders' Lounge | 2 | 06-06-2004 10:42 PM |
