Fisheye eliminator - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-06-2007, 02:31 PM
cyclopsblown34's Avatar
Colorsanding painter
Originally Posted by 302 Z28
Good luck, and let us know how it comes out.
Vincce
Will do, I am going to wash and sand it tonight. Clear tomorrow evening or Saturday morning.
  #17 (permalink)
Old 12-06-2007, 02:33 PM
302 Z28's Avatar
Lighten up on the tack rag also, just drag it accross the surface....no pressure.
Vince
  #18 (permalink)
Old 12-06-2007, 02:36 PM
That could have been part of it as well. I can guarantee I wasn't just dragging the tac rag like a chamois. I was working it like a wash rag.
I will be thanking you and everybody else for days, Chip.
  #19 (permalink)
Old 12-06-2007, 02:42 PM
302 Z28's Avatar
If you really rubbed the tack rag I suspect that is the source of your base fish eye problem.
Vince
  #20 (permalink)
Old 12-06-2007, 02:58 PM
It was worked like a wash cloth so that is probably a big part of it. Like I tell my friends who know it all, I'm still learning.
  #21 (permalink)
Old 12-06-2007, 04:44 PM
Whippetguy's Avatar
Last journal entry: Window templates
Many people make the same mistakes you made, myself included. The first thing a lot of people want to do is sand... bad mistake! You're just grinding any contaminants, such as silicon, into the surface, making it very hard to remove later. CLEAN-CLEAN-CLEAN first, then sand.
And the tack rags, if you rub with any pressure, they will leave way more behind than they pick up.
Good luck tonight!
29 Whippet Street Rod project
38 Chrysler Royal, original, unrestored
  #22 (permalink)
Old 12-06-2007, 06:52 PM
fisher57's Avatar
yes indeed all these guys are right . here is a little tip. also take your tack rag and completely unfold it and make it like a big fluffy ball (loose) and gently use it on the surface. before i tack off a car prior to paint i take rubbing alcohol and put it in a clean (new) spray bottle and use that for a final wipe down and then tack it off . good luck to ya i wish you the best .
  #23 (permalink)
Old 12-07-2007, 06:56 AM
Started wetsanding it last night after a good wash with Dawn. Let's just say I got aggressive with the abrasive grit. I worked up to 600. Tonight 800 and 1200 wash before and after then tomorrow more clear. I thought I had the car devoid of any contaminants seein how I washed it with Dawn before doing any work. I just need to be more particular with preparation/cleaning. My mistake has cost me a bunch of extra time. The good point is, it will have nearly a gallon and a half of clear on it and should polish up real nice. It already has 3 quarts of clear on it now.
All these years of painting cars and on the one I am most particular with, I have a problem like this. Sheesh. We learn all the time, or at least I do.
  #24 (permalink)
Old 12-08-2007, 07:05 AM
bentwings's Avatar
bentwings
I did some painting years ago and fisheyes were big problem. The paint sales guy came in and walked over to the welders and showed us that the MIG spatter cans had silicone in them. We replaced all the cans with non-silicone base and had the shop air filter changes. Problem gone almost over night. He also said no fish eye killer too even though he sold it. after this there was never any silicone based material brought into the shop.
Wash don't sand. Everyone likes Dawn but any good non silicone dishwash soap works well. It's the grease cutting acting you are looking for. Don't press tack cloths. just dust with them.
Make sure you shop vac doesn't blow dust all over. It needs good filters.
I used to fine spray water all over the paint area frome the ceiling down. This seemed to pull the dust out of the air. The floor was also wet so you didn't stomp dust inthe booth air.
I guess it boils down to preparation.
  #25 (permalink)
Old 12-10-2007, 10:27 AM
Thanks for all the tips. No power on Sunday so i couldn't clear. It will bedone tonight and then polished tomorrow. This car is about to kick my butt, I just won't let it.
anyone using AFR's new 195cc Eliminator Head's? 406 ss monte Engine 1 10-09-2006 12:04 AM
C-Clip Eliminator Kit Help leejoy Transmission - Rearend 11 09-04-2006 09:58 PM
accel points eliminator? byrdta76 Engine 7 07-06-2006 10:16 PM
EFE Heat riser eliminator 87442lover Engine 0 08-03-2004 07:13 AM
fish eye eliminator Tattoou Body - Exterior 6 08-18-2003 03:28 PM
