Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fisheye with epoxy
Old 12-13-2008, 01:03 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
I would block it a bit and do not use any more W&G and then shoot the epoxy..filler is kinda odd in that it will vary in density and you will get something looking like fisheyes when you shoot it..let the epoxy induce..wait a few minutes after you mix it and then shoot it..I never reduce epoxy unless it is for a final seal coat and that is only so it will lay out a bit slicker..
Sam
