fisheye with epoxy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2008, 09:08 AM
chas350's Avatar
fisheye with epoxy
Hi fellas
I have fisheyes over my filler/putty after one coat of 10% reduced transtar epoxy. I was going to apply MP182 surfacer next, but dont want to have a problem later.
what should I do?
chas
Old 12-13-2008, 09:12 AM
BarryK's Avatar
Did you clean the filler with wax and grease remover?
Old 12-13-2008, 09:18 AM
chas350's Avatar
Barry I cleaned it twice.
Could it be caused by the w&g remover not fully evaped?
chas
Old 12-13-2008, 10:13 AM
302 Z28's Avatar
chas
Only if you allowed it to evaporate rather than wiping it dry.
Vince
Old 12-13-2008, 10:44 AM
68firebird
Don't let it evaporate... Make sure you wipe it dry. I do small sections at a time and wipe it with a clean rag really good before it evaporates. If you let it evaporate the wax or grease will be left on the panel.
Old 12-13-2008, 11:07 AM
BarryK's Avatar
W&G will do that every-time, filler may have looked dry but filler is a sponge and can hold a W&G for 20-40 minutes after it looks dry depending on humidity.
That is why its not a great idea to wash filler.
Old 12-13-2008, 12:16 PM
chas350's Avatar
This is on a van door with external hinges, I am thinking that contamination caused by spray lube over the years may have been the cause.
I do wipe off the w&g remover with a dry p towel. But the filler holds it and I forgot to hit it with compressed air like I usually do, because I had a visitor.
So, should I just block it down a little and clean again, blow dry then hit it with my MS182 surfacer?
thanks guys
chas
Old 12-13-2008, 02:03 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would block it a bit and do not use any more W&G and then shoot the epoxy..filler is kinda odd in that it will vary in density and you will get something looking like fisheyes when you shoot it..let the epoxy induce..wait a few minutes after you mix it and then shoot it..I never reduce epoxy unless it is for a final seal coat and that is only so it will lay out a bit slicker..
Sam
1st bc/cc -- epoxy prep help needed grouch Body - Exterior 96 12-17-2008 01:38 AM
Quick SPI Epoxy Q... S10xGN Body - Exterior 23 01-04-2007 08:05 PM
Dura Glas then epoxy robs ss Body - Exterior 21 11-21-2005 08:18 AM
Marine Epoxy Primer? rlackey Body - Exterior 10 03-24-2005 05:14 AM
Barry, epoxy adhesion testing? baddbob Body - Exterior 21 03-20-2005 10:12 PM
