Fit turbo on my cutlass - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2003, 11:18 AM
Hi,
I have a 3.8L 1985 cutlass supreme.
On ebay i found a turbo assembly for a buick grand national. It Comes with turbo, intake manifold, and four barrel intake. Buick GNs also had a 3.8L
Would this bolt on to my 3.8L cutlass?
If not would I be able to modify it so it could?
Thanks any input would be great.
Old 07-18-2003, 11:52 AM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
Not too sure if they are direct fit, but anything's possible. If anything, the manifolds don't match. You should be able to use the rest, and get a manifold. But this is coming from someone that's never seen it, hopefully I'm not steering you too far off. Good luck...
Old 07-18-2003, 12:06 PM
I'm not 100% sure but i think buick makes the 3.8L motor that would be in my cutlass.
Does anyone Know??
And would that make a differance?
Old 07-19-2003, 09:55 AM
I'm relatively certain it's a Buick engine, but it's not the same as the Turbo motor, which has a stronger bottom end. You can find a lot of good info on the Turbo cars at www.gnttype.org
Old 09-03-2003, 06:28 AM
SinistrV6's Avatar
valve monkey
Not a "turbo" motor but not far off. The motor itself should be a "109" block (casting number ends in ...109) and the crankshaft MUST be a turbo crank. The turbo cranks have rolled fillets on the mains and rods for additional strength. Now, if you really want to turbo your Cutlass, look for a COMPLETE '86 or '87 Buick Grand National or T-Type drivetrain. Motor, tranny (BRF valve body is specific to turbo cars) wiring harness, intercooler, .... Don't bother with the older non-intercooled "hot air " cars. Nice if you've got one but if your building one step up to the intercooled set up like so many "hot air" guys do anyway.
www.gnttype.org as mentioned above is a good source for all sorts of general Turbo Buick knowledge. More specific to swaps and hybrids is:
www.turbobuicks.com
and the "BIG BOARD"
www.turbobuick.com
Good luck,
Richard
Old 09-03-2003, 01:58 PM
With the amount of boost coming out of the stock turbo your bottom end should be able to handle it. It would be nice to have a turbo crank in, but imo it's not absoultly necessary
1984 Pontiac Grand Prix
-350 4-bolt main
-Torker II Intake
-Holley 600 cfm 4-barrel
-Flowmaster Afterburner headers
-Turbo 350 Transmission
