Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fitting 1972 c10 brakes on a 1963 c10
Old 04-09-2013, 08:20 AM
RWENUTS's Avatar
RWENUTS RWENUTS is online now
If you don't get the 72 pedal then don't lengthen the rod till you drill a hole 1 1/2 lower in your stock one.
You need to maintain your pedal ratio.
The Following User Says Thank You to RWENUTS For This Useful Post:
hman17024 (04-10-2013)
