-   -   fitting 1972 c10 brakes on a 1963 c10 (http://www.hotrodders.com/forum/fitting-1972-c10-brakes-1963-c10-231649.html)
hman17024 04-08-2013 09:04 PM
2 Attachment(s)
i went parts shopping the other day and managed to get the spindles, disk brakes, power brakes,power steering box and pump from a 1972 chevy for my 1963 c10...well i mounted the brake booster on my truck and it seem to fit nicely in the same location as the old one. The arm that connects brake pedal assembly is a tad short but all u have to do is unscrew the arm and adjust it to the length so it bolts to the brake pedal. will this work the way i have it set up or will i have to buy some special kind of bracket? i put it on for mock up. any advice is greatly appreciated
hman17024 04-08-2013 09:31 PM
1 Attachment(s)
heres the picture of the rod that comes from the brake booster to the brake peddle its a lil short but can be lengthen
gearheadslife 04-09-2013 06:11 AM
go get the 72 pedals, problem solved
RWENUTS 04-09-2013 08:20 AM
If you don't get the 72 pedal then don't lengthen the rod till you drill a hole 1 1/2 lower in your stock one.
You need to maintain your pedal ratio.
