the problem is going to be with the converter, crank and flexplate. the flexplate for the 4l60e for your LS is different and more than likely is in a different depth than the older flexplate because of the late 4l60e converters depth. the converter is going to be either a 300 or a 302 mm converter, and the pilots on those converters are different than the typical older sbc., and more than likely will not fit in the back of the crank. as far as switching out to another type of 4l60e converter, that also will not work as the later 4l60e's do not have the polished end of the input shaft for lock up like the older 4l60e's/700r4's do. |
Thanks for the info.
What prevents me from using the kit below to adapt it to my SBC. They specify it's for a 1 piece rear main seal setup, but why wouldn't it work on a two? http://www.jegs.com/i/GM%20Performan...0002/-1?CT=999 Edit: I see now that the part says "Note: You will require an older style flexplate if installed on a two piece style rear main seal small block engine or using the 4L70E trans on a big block engine." So does this mean I could use my current flexplate, and this kit, and get it to physically bolt up?
Bringing history and technology together. Last edited by Siggy_Freud; 09-13-2011 at 10:09 PM. |
from what i can tell, that kit from jegs along with your 307 flexplate should work. the one thing that does concern me though is nothing for the pilot of the converter so, id recommend that when bolting up the converter that all bolts be put in flush before tightening. |
Sounds like I'll have to give it a go.
So you're saying get the bolts flush so I'm sure I get that converter on even? Makes sense. I'll take photos and do a write-up so others can see how its done (or not done hehe).
Bringing history and technology together. |
It will also make sure you have the TC/TorqueConverter installed correctly.
Rotating & Pushing so the Input Shaft splines, Stator Support splines and Pump Lugs/Splines are engaged. TC Install Tips: http://www.tciauto.com/tc/auto-trans-faq#4 http://www.tciauto.com/tc/auto-trans-faq#5 Trans Do's & Dont's: http://www.tciauto.com/tc/dos-donts Trans & TC Fluid Capacities: http://www.tciauto.com/tc/fluid-capacity |
Thanks for the guides and reminders
.Fortunately, I've done a tranny install/removal 3 or 4 times and haven't messed it up yet, but always good to keep the dos and don'ts close in mind.
Torque Converter Install Tips
You're Welcome Dylan,
I try to Post those 2 FAQ Tips anytime a member is dealing with installing a Trans & TC. There have been many members that didn't get the Pump lugs engaged and damaged the Pump/Gears. Sounds like you're gonna have a very fun ride when the LS/60E is dropped in. What rear Gear ratio have you chosen to go with the O/D Trans? Good Calc. here for mph/rpm >> http://www.f-body.org/gears/ & Trans ratios etc.. >> http://www.maliburacing.com/auto_tranny_id.htm Todd |
I'm thinking of going with a 3.23 or 3.55 ratio. Don't need anything too aggressive as this is my DD. The 1-2 drop will be a bit of a bog, but eventually I'll just build the engine to overcome it.
We have a 3.55 in our supercharged stang, and it has plenty of power to overcome the gearing. 1st gear is almost a waste as is. I'd rather have the MPG and comfort on the highway, and then used forced induction to get me the seat of the pants feel I'll eventually want. What do you think?
| Where can I get this fitting? | staleg | Suspension - Brakes - Steering | 4 | 05-19-2011 08:13 AM |
| 2000 4L60E to an earlier 4L60E, What do I need to change out | aquaterrarv | Transmission - Rearend | 2 | 04-08-2010 06:22 PM |
| trans cooler fittings.. 3/8 hose fitting to a AN fitting? | scapegoat | Transmission - Rearend | 6 | 04-14-2008 04:12 PM |
| rim fitting pcd HELP! | 52prefect | General Rodding Tech | 5 | 02-06-2007 08:51 AM |
| Rim fitting | Mirror Image | Suspension - Brakes - Steering | 1 | 03-02-2003 12:28 PM |
