-   -   AN- fitting assembly (http://www.hotrodders.com/forum/fitting-assembly-76876.html)
GCD1962 12-23-2005 01:38 PM
First time I am using the an fittings. Is it correct to tape the end of the stainless hose to insert it into the hose fitting?
curtis73 12-23-2005 02:02 PM
Nope. The tape is great for cutting to prevent the braid from turning into a brillo pad, but it should be removed for assembly. Pain in the *** isn't it?
Rick WI 12-25-2005 10:20 PM
We tightly wrap one layer of duct tape at the proper cut length. We cut the end and leave the remaining length of duct tape on the end for the fitting, We install the end and trim off any excess tape. Has worked well for us for at least 15 years.
Canadian Charlie 12-26-2005 01:42 PM
I wrap mine a few wraps of electrical tape and then trim it off when I get it all assembled. Use those aluminum insert that you put in the vice so you don't scratch the fittings
hotroddr 12-26-2005 05:51 PM
AN fittings
Greetings! I have used strapping tape for a good 20 years, haven't had a problem leaving it on. I get the best luck using a really thin disc to cut the stainless. There is a new tool on the market for assembly, looks like it ought to make the job simple. Bill :)
