Fitting a big block in a chevy II - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2012, 11:04 AM
Hey guys I was just wondering how hard and how much work and money does it take to fit a bbc in a chevy II? Is it worth doing.
Old 06-17-2012, 11:45 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Depends on how much of the work you can do yourself. For that matter, in your earlier posts you talk about your dad having a 496 hot rod and an uncle with a 668 c.i. BBC making 2,000 hp. Maybe they can pitch in, they must know what direction to take.
Do you intend to DIY or have it done by a shop?
Semper Fi
Old 06-17-2012, 12:42 PM
junior stocker's Avatar
62-67 Chevy II/Nova? If so, the shock towers need to be cut back, or an aftermarket front suspension clip installed with new inner fenderwells. 1968 Chevy II/Nova? Those actually came with a big block option and is a true bolt in. 62-67, I'd use a big inch small block rather than a big block. junior stocker.
Old 06-17-2012, 12:47 PM
Banned
Bolting the engine in is the easy part, its what goes between the engine mounts and behind the flywheel that becomes the PITA. You have to build a big block car, not just put one in. Fwiw depending on what you want a boosted sbc 350 can give you a lot of streetable power.
Old 06-17-2012, 06:03 PM
I have a 1962 Chevy II and when I got it there was just a 283 sbc in it and that was a tight fit! I'm a newbie at this kind of stuff but I feel like it would take a lot of work and not really be worth it. Personally I'm just going with a 400 sbc which i feel like will be enough power for how much it weights!
Old 06-17-2012, 06:06 PM
And I'm not sure if you could even cut the shock towers back that much cause the coils seem to fit in almost right up against it so you could only get another 3-4" in my opinion.
Old 06-18-2012, 07:30 AM
go to "steves nova site" and ask.
Old 06-18-2012, 07:35 AM
if your leaving front end stock go with smallblk takes special oilpan and oilpump and pickup tube they sell kits. the cool thing is the front unbolts you can go in and fab the front frame ,hang a straight axle big block and super koolllll. and don't forget to cut rear fenderwells out to get some meat on the outside
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 08:36 PM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 08:26 AM
Big Block Chevy ... How much does a block weigh Rob Keller Hotrodders' Lounge 5 03-24-2008 07:10 PM
Aftermarket Block Big Block Chevy camaro 68 Engine 2 09-15-2003 09:19 PM
55 chevy small block to big block ehchvac Engine 0 05-02-2002 09:23 PM
