There are some posts at www.maliburacing.com on using the 8.8 in GM G-body's, you might search there.
This is a good write up http://www.theturboforums.com/smf/in...topic=104354.0 Last edited by zildjian4life218; 12-29-2010 at 08:08 PM. |
offset pinion
I have a question thats revelent to the thread if you don't mind ZJ4L. With the nine inch pinion being offset, is one axle tube and axle shorter/longer to center the pinion in the frame or did all the fords run drive lines that were off center to the frame? One tube shorter/equal axle length? Not being familiar with it just got me wondering.olnolan
Someone else might know of some others. Pretty much going to come from cars that have a factory 4-link rear and the upper arms attached to the pumpkin. Mid 70's LTD/Thunderbird is 4-link, but seems like all the arms attach to the axle tubes(like the 71-73 Vega does) and nothing to the pumpkin so it doesn't need to be centered. |
Engine is almost always centered from what I know, driveshaft runs down the tunnel on an angle to get to the offset pinion flange. Can't tell you on the tube lengths and axle lengths.
Even GM stuff with equal length axles(10 bolt, 12-bolt) have a pinion offset to the passenger side, engine centered, and the driveshaft goes down the tunnel on an angle. GM offset the BBC engine to the passenger side in '67-69 Camaro and '68-70 Nova, but that was just so the exhaust manifold would clear the steering box, not to match the rear axle. I don't know of a single car that has an absolutely centered pinion gear so that the driveshaft is straight from the trans to the pinion flange, the driveshafts are all angled the amount the pinion is off centerline of the rear case. The driveshaft is never perfectly parallel to the engine centerline as it heads to the rear. A lot of people seem to mistakenly think the driveshaft runs through the car/truck exactly parallel with the frame rails... it never does in any car I've ever seen. |
Maybe I'm missing something cause I always thought the GM pinions were centered like in this photo;http://www.google.com/imgres?imgurl=...w=1276&bih=575
pinion centerline
Thanks for the tip Eric, To the naked eye it looks centered. I guess less than an inch of offset over the length of the driveshaft will still operate smoothly? I guess you can tell I've never done alot of driveline setups from scratch, mostly just worked with what was there.
Still curious about the nine inch tube/axle lengths. Nolan |
Mustang 8.8 |
http://cgi.ebay.com/ebaymotors/9-For...#ht_1850wt_939 Last edited by zildjian4life218; 12-30-2010 at 07:23 AM. |
No. The center of the housing is cast iron. You can't weld the brackets on cast iron. You must find a rear end that already has the eyes cast into the top of the housing or use a housing that is made of mild steel, like the 9 inch or 8 3/4 Chrysler, so that you can weld the brackets on.
| Early Ford Spindles fitting early Ford axles | pasadenahotrod | Suspension - Brakes - Steering | 3 | 08-14-2012 07:20 PM |
| Painting a Metallic in pieces | Polish Painter | Body - Exterior | 18 | 09-11-2010 06:16 AM |
| Need expert advice on 56 ford car | ctfortner | Hotrodding Basics | 20 | 07-15-2008 09:53 AM |
| how would you make it legal?? | spooki | General Rodding Tech | 8 | 08-31-2003 09:16 AM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
