Fitting Steel parts to Fiberglass? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2006, 01:11 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Guys,
Maybe an ignorant question here, but a question nonetheless. On my coupe, I will be running Fiberglass fenders, and, I am going to run a Hagan Fuel Door as well as Hagan flush mount lights. I am wondering if and how I can mount these items (which are Steel) in the fiberglass fenders? If I do, will there be stress cracks (or other problems?) down the pike?
I can buy the Hagan flush mount tear drop lights which would not require a steel surround, and I can put the Fuel Door in the quarter panel, but I would like some opinions here as putting the Fuel Door in the quarter will be a long way from my Tank, and I would like to keep the Fuel filler as close to the Tank (Rock Valley) as possible.
What do all of you think?
thanks,
Craig
Old 01-12-2006, 01:59 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Your question?
If it were mine and the fuel door required the hinges to be fastened with screws I would glass in a piece of sheet metal on the backside of the fender and use self drilling screws to anchor the door hinge..Thats one way that can be done..The fuel pipe box can either be fabricated to fit or perhaps one can be found in a wrecking yard that can be adapted..Grab the upper fuel pipe and gas cap if you can..
On the tail lite housings one can rough up the housing with some 60 grit and tape it into place and then glass the housing into the fender for a nice molded in look.
OMT
Old 01-12-2006, 03:17 PM
What I would do is cut the hole where the part will go, cut it VERY close to perfect. The gas door one for instance would be EXACTLY as big as the hole in the metal surround that came with it. The tail lamps, same thing. Grind the back of the fenderb GOOD, kinda thin even, once you have the hole where the part will mount, then grind the top of the metal surrounding the gas door or tail light pocket, then bond the part in using an adhesive designed for this. The tiny joint at the edge would have adhesive oozing out that would be sanded flush and primed.
Prior to primer all you would see from the outside is a hole with metal the metal pockets and a tiny smoothed out seam around the edge.
Old 01-12-2006, 04:43 PM
35WINDOW's Avatar
Thanks to you both for the replies-now, what about the extended life of doing this? Will the 'glass and the metal delaminate or be prone to cracking?
Brian, regarding the surround to the Gas Door, would you put the metal to the outside then? That is the obvious vision that I have here-then which product would I use to "feather" the parts (not show a parting line)?
Thanks,
Craig
Old 01-12-2006, 07:24 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
Brian[/QUOTE]
TAP PLASTICS has a 2 part epoxy adhesive that is designed for this type of bond,, I use it all the time,, do like Brian said and make sure the adhesive spreads up between the glass and the metal,, you can also use this stuff for bonding studs for attaching the light buckets,, it is a 2 color mix, white and black,, Bill
Old 01-12-2006, 08:36 PM
Thanks,
Craig
I am talking about putting it on the inside, THAT is the point. If you bond it to the inside and have a hole that is EXACTLY the same as the gas doors "pocket" that they want to you weld into a fender you will only have the small seam RIGHT AT the edge of the hole.
Vettes where held together just like this for decades. A 68-82 Vettes door for instance is a metal frame with a fiberglass skin "glued" on with "Vette Panel adhesive" which is one thing you could use.
Old 01-13-2006, 07:19 AM
35WINDOW's Avatar
Thanks to you both for your replies. Sorry, I was having difficulties understanding the concept. Sounds like a great long term solution-
thanks again,
Craig
Old 01-13-2006, 11:17 AM
I'll draw up something and post it tonight.
Making Fiberglass Parts Maverick Body - Exterior 19 04-19-2005 09:29 AM
More fiberglass questions... Slipangle Body - Exterior 0 04-16-2004 09:36 AM
fiberglass scoop to steel hood mooneyes4b Body - Exterior 6 11-06-2002 03:19 PM
Fiberglass parts. tetzlaff Body - Exterior 8 09-22-2002 01:55 PM
fiberglass body parts dusterbd Body - Exterior 4 09-19-2002 08:31 AM
