Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 01-25-2004, 03:17 PM
ets1945's Avatar
ets1945 ets1945 is offline
AN fittings??
I've never used the AN8 fittings before. Do you trim away the metal jacket and only insert the rubber hose into the fitting, or do you insert the metal jacket too? Seems to work both ways
Old 01-25-2004, 03:52 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
re: AN fittings??
The metal jacket has to go into the fitting if the fitting has a ferrule on it (crimp type) or the internally threaded hand assembled type
Old 01-27-2004, 07:08 PM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
re: AN fittings??
Since this is your first time playing with steel braid and AN fittings, just be very patient. It takes a while to develop your own tricks. IT will test your patience and you will get pricked by the steel braid. The most crucial thing is that you have a good clean cut (no fraying). I have been able to accomplish this a couple ways (always wrap the area to be cut tight with tape), a cutoff wheel will work, as well as a SHARP wood chisel (there are several other ways). There are a particular type of wire type cutters that work well I have yet to buy a pair.
I hope that helps some.
Royce
Old 01-28-2004, 05:42 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Moderator
re: AN fittings??
As stated above, wrap the area to be cut with tape and use a cutoff wheel, like a Dremel. I have not had much luck at all with a chisel, even a sharp one. You can buy a cutoff machine at Harbor Freight for about $20 that is perfect for this.
Vince
Old 01-30-2004, 06:17 PM
ets1945's Avatar
re: AN fittings??
Tried my air cut off tool.....doesn't seem to get it too smooth. Maybe the wheel is too thick?? I'll try the dremel tomorrow.
Alreadt screwed up about a foot of hose Guess I'll have fun this weekend
Old 01-30-2004, 06:45 PM
5window 5window is offline
re: AN fittings??
I have tried wrapping the hose tightly with several layers of masking tape and then using a new, 32 tooth hacksaw blade to cut through the middle of the tape. It does an okay job-occasionally
I have had to trim a wisp or two with wire cutting pliers.
Old 01-30-2004, 06:50 PM
ets1945's Avatar
re: AN fittings??
I have made a couple of ok cuts....just can't seem to get the jacket to go into the fittng smoothly even with the assy lube.
Just a learning thing I suppose. Can't give up just yet.
Old 01-30-2004, 07:08 PM
hotwheels55 hotwheels55 is offline
re: AN fittings??
Others laughed when I commented how I learned to get the braided steel hose into the AN fittings/ends.
I tightly wrap the end of the hose twice with masking tape. I prefer the blue painters tape. The braided hose has to be clean obviously for the tape to adhere. I use a DREMEL cut off wheel to cut the hose. I leave the masking tape in place at the end of the cut. I apply a liberal amount of lube, insert the fitting/end into a vise (with soft aluminum jaws) and twist the hose into the fitting/end. The tape allows the braided hose to slide into the fitting/end and not fray. If any of the tape is still exposed after the hose is bottomed into the fitting/end, it is easily trimmed away.
I went through a lot of wasted -6 hose until I started doing it in this manner and it works for me everytime.
Old 01-30-2004, 07:12 PM
ets1945's Avatar
re: AN fittings??
That is what I thought about doing....leaving the tape on....doesn't that give a chance of the fitting not gripping the hose and causing a fuel leak?
Old 01-30-2004, 07:34 PM
re: AN fittings??
I have approx. 25 feet of braided steel -6 AEROQUIP hose used throughout my '57 150 sedan. I used it not only for all fuel lines, but also for brake booster and brake booster reservoir. I've had no leaks yet...not to say that couldn't happen.
The part that is inside the fitting/end will "grip" just as well, maybe better (?), with the additional thickness of the tape around the hose. It's what has worked for me, eliminating the fraying the ends of the hose and wasting material.
I'd also suggest you use an antiseize on the threads of the male to female AN fitting/end. The fittings are aluminum and the proper sealing doesn't require to be gorilla'ed tight, just snug.
Old 01-31-2004, 05:10 PM
ets1945's Avatar
re: AN fittings??
I tried leaving about 1/4" of the tape on the braid.....worked like a champ
Pulled on the hose after assembly pretty hard...no slippage Gonna watch the joints pretty close during the cam break in.
Old 01-31-2004, 05:20 PM
re: AN fittings??
I'm glad that worked for you...I've been vindicated and my medications can be reduced...
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
