Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Five inch sanding disks with 1/2" hole
Old 01-16-2013, 02:37 PM
Mutt's37Buick's Avatar
Mutt's37Buick Mutt's37Buick is offline
Bought a Makita 5 inch sander (model GV5010) to grind the welds as I weld in replace metn Very light weight at 2.6 lbs. Can't seem to locate sanding disks. Looking for 24 or 36 grit disks. The sample disk has a 5" outer diameter and 1/2" inner diameter.
1) Can anyone tell me a store in the Denver area that carries this type of disk.
2) I see Aluminum Oxide, Ceramic, and Zirconia fiber disks are common. Can anyone tell me the best type of disc for grinding mild steel welds on my sheetmetal welds?
Thanks
