-   -   Five inch sanding disks with 1/2" hole (http://www.hotrodders.com/forum/five-inch-sanding-disks-1-2-hole-228468.html)
Mutt's37Buick 01-16-2013 02:37 PM
Bought a Makita 5 inch sander (model GV5010) to grind the welds as I weld in replace metn Very light weight at 2.6 lbs. Can't seem to locate sanding disks. Looking for 24 or 36 grit disks. The sample disk has a 5" outer diameter and 1/2" inner diameter.
1) Can anyone tell me a store in the Denver area that carries this type of disk.
2) I see Aluminum Oxide, Ceramic, and Zirconia fiber disks are common. Can anyone tell me the best type of disc for grinding mild steel welds on my sheetmetal welds?
Thanks
35WINDOW 01-17-2013 08:52 AM
I use a lot of 5" 3M "Green Corps" Discs for grinding welds, and they have done a great job for me (your mileage may vary)-
At any rate, I would go down to Tool King on 6th & Simms (just east, on the north frontage road)-they have them, although I did buy them once at a place in Arvada (closer to you), on Ralston Road (but I can't seem to find them in the Yellow pages)-
Anyway, any good local Paint Store should have them-hope this helps-
ToolKing.com: 3M 31915 Green Fibre Discs 5-inch x 7/8-inch Arbor 24G - 10-Pack
OneMoreTime 01-17-2013 09:59 AM
Check on these guys:
industrial supplies near Westminster, CO - Bing Local
Also McMaster Carr as they have fast shipping and decent prices. buy the boxes of 50 or 100 as that is the better deal..
Sam
