Five inch sanding disks with 1/2" hole - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2013, 03:37 PM
Mutt's37Buick's Avatar
Bought a Makita 5 inch sander (model GV5010) to grind the welds as I weld in replace metn Very light weight at 2.6 lbs. Can't seem to locate sanding disks. Looking for 24 or 36 grit disks. The sample disk has a 5" outer diameter and 1/2" inner diameter.
1) Can anyone tell me a store in the Denver area that carries this type of disk.
2) I see Aluminum Oxide, Ceramic, and Zirconia fiber disks are common. Can anyone tell me the best type of disc for grinding mild steel welds on my sheetmetal welds?
Thanks
Old 01-17-2013, 09:52 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I use a lot of 5" 3M "Green Corps" Discs for grinding welds, and they have done a great job for me (your mileage may vary)-
At any rate, I would go down to Tool King on 6th & Simms (just east, on the north frontage road)-they have them, although I did buy them once at a place in Arvada (closer to you), on Ralston Road (but I can't seem to find them in the Yellow pages)-
Anyway, any good local Paint Store should have them-hope this helps-
ToolKing.com: 3M 31915 Green Fibre Discs 5-inch x 7/8-inch Arbor 24G - 10-Pack
The Following User Says Thank You to 35WINDOW For This Useful Post:
Mutt's37Buick (01-17-2013)
Old 01-17-2013, 10:59 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Check on these guys:
industrial supplies near Westminster, CO - Bing Local
Also McMaster Carr as they have fast shipping and decent prices. buy the boxes of 50 or 100 as that is the better deal..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
4 inch hole grommet J-ree Electrical 11 07-20-2012 06:02 PM
Two "NPT" Hole Thermostat Houseing Who Makes It Viet Nam Vette Engine 25 08-20-2009 06:50 AM
Can I use the same arbor for 2" & 4" 3M disks? FrankR Body - Exterior 4 12-14-2005 04:14 PM
SBC "threaded hole in lifter valley" Stroker56 Engine 6 04-17-2005 09:41 PM
How to clean gunked-up sanding disks willys36@aol.com Garage - Tools 3 04-04-2004 07:43 PM
