Five Star Primer ?
I went to the local autobody store and asked for an epoxt primer and he gave me "5 Star Extreme". I've been reading up on it and it seems to be a hybrid epoxy/acrylic. Has anybody else used this, will it stand up as well as a straight epoxy primer?
http://www.autobodybrands.com/primers/5425_x2k.html I have some sections that I used POR15 and POR15 tie coat primer and I'm wondering if I can spray over that as well so everything in a uniform coat of epoxy. Any input??? Thanks, Sean |
I am not a pro, however I used this same product and it turned out pretty well I think. I had a friend spray the color and clear and the final product turned out well.
One other thing: It sands nicely. I did a LOT of blocking, and it sanded out real nice. See the picture below Last edited by rwilliam99; 10-27-2008 at 05:10 PM. |
I cant comment on its long term endurance but I can say this.
If its the 2k "Extreme" DTM Primer/Surfacer/Sealer ****, that stuff sands absoutley terrible. I find it to be very soft, and clogs up the paper very quickly. If you happen to catch and edge, or are not careful you will gouge into your just sanded finish. To me, its fine for small parts. But I would not want to sand an entire car coated in the stuff....way to much paper and time. |
I have never used that product, but I do know that epoxy's in general are a pain to sand. Epoxy is good as a sealer and direct to metal. But I prefer to use a 2K urethane primer for bodywork/blocking. There are a few epoxy's out there now that claim to be sandable but I have never tried them. I"m assuming thats what this 5 star product is. Now that I think about it I used some SEM Metal Lock primer that was Direct to metal. and it may have been an epoxy, it sanded ok if I remember right.
It won't be as durable as a true epoxy primer and solvent resistance is not as good but most of these hybrids trade off those qualities for sandability. If you're looking for a true epoxy primer that sands well SPI is the best I have found. Many are using it from start to finish now. |
SPI Epoxy sands awesome and adheres great. I see no reason to not use it instead of ANY other dtm primer or treatment.
I must add that I do not use any por type products and dont believe in painting over rust, so I have no idea how SPI Epoxy would perform over such substrates. |
When an epoxy balls up and gums the paper its most likely not completely cured OR it wasnt properly mixed to the right ratio....I've had epoxy take a week to cure sometimesbut it was really piled on there |
After having this trouble with it, I thought it must be an epoxy hybrid, and SOME five star xtreme high build primer is a hybrid. Xtreme 5425 IS a hybrid, it says so in the description, but what I used, Xtreme 5451 says nothing about being a hybrid. All I know is, I used an Eastwood epoxy on this car and it is not that much worse to sand than this 5 star 2k, I've never used a 2k this bad to sand. I'm just going to sand it down as much as possible, and reprime with another primer. Probably Sherwin williams, since that's the BC/C I'll be using. Anybody use Sherwin Williams primer?
Primer........
I sprayed my 28 Ford Roadster pickup with SPI epoxy primer,I LOVE IT,the neat thing is,that it (SPI)has a good shine.so,very easy to sand and see when its smooth and ready for the topcoat of paint...
| star | lanier ledford | Off-Topic | 6 | 12-02-2010 12:00 PM |
| 5 star Maxx fill 2k primer | mitmaks | Body - Exterior | 2 | 02-08-2010 05:52 AM |
| my car going to be a star | dawg | Hotrodders' Lounge | 7 | 04-26-2007 06:27 PM |
| 5 Star Xtreme 5425 2K Primer | crashtech | Body - Exterior | 0 | 02-16-2006 07:59 PM |
| my friend's body is a star. a shooting star | bullheimer | Hotrodders' Lounge | 4 | 08-26-2004 10:31 AM |
