fix cracks in plastic steering wheel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2004, 01:18 PM
project66's Avatar
how or what do you use to repair steering wheels? It is an original steering wheel from a 51 mercury, it is some type of black plastic type stuff. It has a few small cracks down to the metal. What can be used to repair this or can it even be fixed? A new original one is just way to much and i dont want to put an aftermarket one on there. thanks
Old 10-06-2004, 03:18 PM
Dave E Shank's Avatar
HEY 66: I had a similar problem with a steering wheel in my 1954 Chrysler. I purchased a rebuild kit from Eastwood and it worked great and was simple to use. Would make a good wintertime project WWW.eastwoodcompany.com GOOD LUCK...DAVE
Old 10-06-2004, 07:15 PM
poncho62's Avatar
Wiki Edits: 5
You can fill the cracks with a good quality epoxy, sand it smooth and paint it.
Old 10-06-2004, 10:50 PM
pzatchok's Avatar
OddJob
I use JBweld
Works great, lasts forever. Then I paint it to match the interior.
Old 10-07-2004, 11:04 AM
VWFan's Avatar
Farfegnugen
Last journal entry: logo fun!
Thanks Project66, I had the exact same question!
So, what kind of paint do you use? Like the same stuf for the exterior of the car, or just rattle-can paint? I don't want it rubbing off!
Old 10-08-2004, 07:11 AM
project66's Avatar
thanks for the info, i will give one of them a try and let you know how it comes out
Old 10-09-2004, 12:24 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Go see my Project Journal. I used epoxy putty I got from the Por15 folks (same as Eastwood's) and it worked great.
