Fix engine or buy crate - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 01-17-2011, 12:24 PM
BigEd36's Avatar
I've never paid attention to the effects on mileage by a cam change, but, I would think a cam that puts your rpm in line with where you get the best torque should give good mileage. It seems that the rpm where you're getting the best torque should be the rpm where the engine is the most efficient, and that if it gives you the best torque then you don't need to give quite as much throttle, so that should give better mileage. But I could be out in left field on this. I do notice looking thru the cam listings on some of the mfg's websites that the cams in the "rv/towing" class have descriptions along the line of "smooth idle, street, towing, fuel economy". I'm hoping some of the guys with more info on mileage will chime in with some info.
Good luck on whatever you decide Bruce. With the price of gas now economy is becoming more important than ever. I rarely drive my pickup any more, unless I need it, due to how much more gas it takes than my car.
Ed
  #47 (permalink)
Old 01-17-2011, 05:14 PM
My winter project is to install an Innovate LM-1 wide-band Air/Fuel ratio gauge and try to tune my carburetor a little more for economy. I'm running an Edelbrock 1406 right now, but still have the old Quadrajet that came with the truck.
I've got the AFR gauge wired up and it checks out good when I calibrate it. Now I have to get the exhaust shop to weld in the bung for the O2 sensor. Innovate uses a heated wideband sensor, so the exact placement is very flexible. I can only monitor one side with one sensor, but that should be enough for now.
Bruce
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 07:48 PM
Crate Engine JMEDLEY001 Engine 3 12-31-2006 10:33 PM
crate engine StreetRacer Engine 8 04-26-2005 01:31 PM
350 crate engine Seon Engine 2 11-13-2002 06:58 PM
Crate Engine 1Hokie Engine 4 03-29-2002 05:58 AM
