fix a flat in air shocks?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2007, 10:28 AM
If i had a set of air shocks that were giving me problems with leaking Could it or would it be possible to use some fix a flat to slow it down or maybe even stop it all together? I know the instructions for using on a tire say to drive it for so many miles once putting it in. Im guessing this is to distribute the stuff evenly and seal while letting it dry or harden or what ever it does. So im not sure if this is even a good idea or would ruin anything. Just a thought all opinoins welcome.
Old 09-13-2007, 11:02 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I don't believe it will work.
Old 09-13-2007, 11:14 AM
poncho62's Avatar
Wiki Edits: 5
Chances are, they are leaking in the hose fittings rather than the shocks themselves. Another tip.........don't overtighten these fittings....it only makes them worse.....or collapses the hoses, so air won't go in.
Old 09-13-2007, 02:16 PM
ccb ccb is offline
fix a flat will not work. Get under with dish detergent and look for bubbles. fix the leak.
Old 09-14-2007, 11:02 AM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
i had a set of air shocks on my 70 elky and i had to fill them up every couple of days. i couldnt find the leak so i got rid of them. personally i would just get rid of them there are much better shocks out there that are adjustable.
Old 09-14-2007, 07:15 PM
Just to add some nifo here...but the "fix-a-flat" stuff needs to be "coated" and absolved...that's why the directions say somethng like "drive "xx miles" after putting it in.
There's no rotational thing going on in air shocks to aloow a coating of anything...would be like if you had a flat tire and stuck in a can of Fix-a-flat, then let the car sit for a week, chances are you'd come back to a flat tire.
Old 09-14-2007, 09:38 PM
take them off, put in some slime,roll them and compress them for a little bit then put them on air them to a low preassure and drive down a bumpy road....or buy some new ones there only like 35 a piece for gabriel air shocks....but I have had excelent luck with slime in tires so it may be worth a shot
Shane
Old 09-15-2007, 10:49 AM
Thanks guys i just bought them a few weeks ago and was curious so when i out them in if they leak i had some recourse. Ive only ran air shocks once before and had pretty good luck with them.
Old 09-15-2007, 11:11 PM
E.T. divided by $ spent= Speed
That green slime stuff is sposed to be real good for tires.
But It might plug the lines to the shocks.If ya can't find a leak in the lines and ya think its the shocks them selves you might try it as a last ditch effort.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
air filter location. yus Engine 1 08-04-2006 09:28 PM
Bad Air Valve black66 Electrical 8 04-12-2005 01:44 PM
How do I safely disconnect air bag to fix horn button? MadRabbit Electrical 4 03-08-2005 06:57 PM
air shocks dragon wagon Suspension - Brakes - Steering 5 03-11-2004 05:07 AM
