fix this header ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2008, 08:12 PM
Vortech 4.3's Avatar
jack of all trades
fix this header ?
bran new (had em a year. bought from summit, just now installing) HOOKER SUPER COMP headers. passenger side fit perfect. drivers side, anything but perfect. 1st pic, the pipe is aimed right at the control arm bushing .
2nd pic. the collector is right up next to the trans, and the shift lever is not even bolted on. these were not bent while i owned them, and i doubt during shipping (no dents at all). i think they were jigged wrong. but 1 year later, i doubt i have any recource.
they are not coated yet. that is just cheap white paint. i wanted to see how an old school white header would look.
my question : anyone have issues like this, and how did you fit them ?
(i have some ideas. but they may be bad ideas.)
thanx
(sorry for the large pics, i didn't realize the camera was set so high).
Old 04-02-2008, 03:43 AM
headers
i say call summit if you never has them installed they might exchange them. i bought a summit 2.1/8 water gage had it for six months when i went to put it on, i find the copper tube is broken at the connection. they replaced it i had to pay for shipping
Old 04-02-2008, 07:08 AM
Notorious's Avatar
Hot rodder, not street rodder!
If you can get them to exchange them for something else, that'd be my choice. Some of the most ill-fitting headers I've seen over the years have been Hookers. They seem to have a real and ongoing problem with consistency within a given application.
Old 04-02-2008, 07:16 AM
poncho62's Avatar
Wiki Edits: 5
If you are stuck with them.......I have bolted them on, put a long piece of pipe in the collector as far as you can and give it a good reef.....They will bend over some.
Old 04-02-2008, 08:08 AM
cboy's Avatar
Last journal entry: Finished
I've never tried to exchange something over a year old with Summit but I have with Speedway, and they were very accommodating. Particularly if you are simply requesting an "exchange". Email their tech dept. and send along the best pics you can get showing the problems (downsize the pics if possible...Microsoft has a free program you can download to do this.) It's worth a shot.
Always learning...and sharing what I've learned.
Old 04-02-2008, 06:38 PM
jack of all trades
thanx, guys. i think i am stuck with them. i'm going to try bending them. perhaps some heat will help. ya know. i have yet to buy a part and put it on without modifying it somehow. even when i didn't want to modify it
Old 04-02-2008, 07:12 PM
poncho62's Avatar
Wiki Edits: 5
I wouldn't heat them....If you heat just one area, it is going to bend more there, and may buckle.......If unheated, they should bend over a larger area....It doesn't take much to move the collector over a bit.
Try and find a piece of pipe that just fits inside the collector.
Old 04-02-2008, 07:25 PM
jack of all trades
yeah. i'm going to try it cold. you say it will work, so thats what i will try. but if i did heat them, it would be over a wide area and not to glowing. but this is why i asked, you guys have delt with this issue, i have not, yet. wish my LUCK, cause i'm going to need it.
Old 04-02-2008, 07:41 PM
poncho62's Avatar
Wiki Edits: 5
Way to put the pressure on me...........Now, I am gonna be up all night worrying about it.............. ...Kidding..
It worked a couple of times for me,,,,you shouldn't have a problem, especially since the headers are still in new condition.
Old 04-02-2008, 08:01 PM
jack of all trades
well, if it doesn't work, it will be all YOUR fault ....
but, i may have problems. i need them to bend only about 6" before the collector. otherwise they will be hitting the frame where the lca mounts (can be seen in the pic). and the pipe may dent from the frame.
Old 04-02-2008, 08:16 PM
poncho62's Avatar
Wiki Edits: 5
Yeah,,,can see that...I would put a piece of plywood in between the header and frame will bending it.....that will spread the pressure against the pipe. I would also bend it down as much as out.........
Old 04-04-2008, 07:39 AM
jack of all trades
i did some bending yesterday. turned out pretty good, though i need to do a little more.... the first pic, the piece of pipe that is not there. i had to heat that and bend it so it matched up with the moved down pipe. they now clear the uca. it did kink a little, as you said it would. but its not bad, i may fix it, i may leave it (its kinda hard to see, so no biggy). a little more work on this, and then i can get to work on the cross memeber, and move some wires.
Old 04-04-2008, 07:46 AM
poncho62's Avatar
Wiki Edits: 5
Glad it worked out....I was going to suggest that you put that missing pipe in place before you bent it, then it would flex too, but I forgot...........Now, you can call them "Custom Fit" headers....................
Old 04-04-2008, 08:16 AM
jack of all trades
i couldn't put that pipe in place, it just wouldn't fit.
i just read in another thread, that hooker headers are made in mexico, is this true ?
custom fit, lol. yeah, i guess i could call them that. but up until last night i was calling them other things.
Old 04-05-2008, 07:40 AM
jack of all trades
i did some more work on it yesterday. i pretty much waisted my time. down below is fine. the small pipe doesn't fit quite right, and this makes the hole length too close to the control arm (even though i trimed the control arm).
so i'm going to get another piece of pipe and weld it in.
these headers are made for 1st gen s10's, and mine is a 2nd gen. but a few guys have these on their trucks and they say they went in pretty much just fine. but my luck would have it that they didn't.
Header Painting How To Full Throttle Engine 33 03-08-2006 01:06 PM
Header Clearance Issues with Pitman Arm k2mooch Suspension - Brakes - Steering 4 04-26-2005 01:35 PM
Oil filter hitting header???? Robbie Engine 19 04-09-2005 09:35 PM
Header leak help tm454 Engine 2 12-18-2003 10:53 PM
Header Fix? 72 chevy Hotrodders' Lounge 4 06-29-2002 11:22 AM
