fix scuff mark on fender, HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2008, 06:20 PM
My cars been painted about 7 yrs ago with clear coat etc the whole 9 yrds. My fender got scuffed with a falling object about 1inch wide and about 4inches long. Just the paint came off, because I can see the grey primer only. My fender is black! How can I fix this the easiest and most simple way? Walk me thru, thanks, Dana
Old 04-06-2008, 06:46 PM
scuff mark.
if you haven't done this before .if I were you i'd just take it to a shop, its a lot of work. get a book at Boarders on the subject they will show u step by step
Old 04-06-2008, 11:39 PM
Feather the damaged area out with 320 grit.
Spot prime with a good 2k urethane primer, guide coat.
Block sand the repair area with 600.
Scuff the whole fender with a gray scuff pad (and scuff paste if you want) and water, scuff very well.
blend the base coat, will most likely take 3 coats or so.
clear coat the fender.
color sand and buff.
Old 04-07-2008, 07:30 AM
Alexflacco, thanks for the info, the kind of response I was lookinf for, not the response to take it to a shop and have it done? Thanks again, Dana
fender fix (Really Bad) Help! 39chevy Body - Exterior 3 11-02-2006 06:43 PM
I need help with fender patch panels. unstable Body - Exterior 6 03-28-2005 08:27 PM
37-39 rear fender welt/ fender repair? jcarter Body - Exterior 8 02-17-2004 07:41 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
