Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fixes
Thread: Fixes
Old 10-14-2012, 08:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Fixes
Over all, the improvements to the site (too numerous to mention them all) are appreciated.
Other than the problems listed already, here are a few to consider:
This has been fixed only when using the white skin.
• Wiki post count frozen. IMHO this feature could be replaced w/a barnstar indicating who has edited.
• Last photo frozen. Fix it or remove it, either way.
Wiki Tech Article Updates on Home page frozen. Same as above- if its going to be there, it should work.
• Would like more tags than two per member per thread
• Add a tag search feature
• Add spell check
New Posts button includes old posts
• More/different smilies has been mentioned
• When replying to a PM, make Request a read receipt for this message the default setting for PMs. Or set it up so if you choose 'Request a read receipt for this message' ONCE, that option will stay until removed, instead of having to select it every time a PM is sent.
• Make the old search engine more accessible than where it is now. Even putting it nearer the top of the page where it is now would help; where it is now, you'd never know it was there if you weren't told about it or accidentally found it. Or, add the ability to to the Google search engine.
