fixing clutch chatter, everything is apart, what can I reuse? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2008, 12:18 PM
well I developed clutch chatter in my 4 speed 67 camaro about a year ago and I'm taking the tired 350 out for a 454. I got the new "used" flywheel and my old clutch disc and pressure plate match up perfectly to the 454 flywheel. The trans is a borg warner super t10.
My question is should I just get the 454 flywheel resurfaced and use the old disc and pressure plate? I plan on selling the car soon and would like to avoid not spending money on new parts if I don't have to.
here is a picture of the old flywheel that had clutch chatter
old pressure plate
old disc
as you can see there is plenty of life left on this clutch
I dont have a picture of the newer flywheel but it looks better than the old flywheel that experienced clutch chatter....but i'm going to have it resurfaced anyway. Also the pilot bushing in the old motor was a little chewed up and there will be a new one in the 454. What do you guys think I should do?
Old 11-04-2008, 12:25 PM
Last journal entry: 50 Ply wagon
Get the flywheel resurfaced and have it checked for heat cracks. Then put in new clutch/pressure plate. If you go with new, you should not have any problems.
Old 11-04-2008, 01:07 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Once they chatter you are up for a new/rebuilt clutch and pressure plate i have found..replace the throwout bearing as well..If you try and sell the car a chattering clutch will ruin a sale..
Sam
Old 11-04-2008, 04:57 PM
RetroWill's Avatar
Just make sure your mounts are all good and you don't have any bushings sloppy in the rear.....alot of times even new clutch parts won't do any good if you have something worn and allowing the drivetrain to move around....even slightly, as you release the clutch.
Old 11-04-2008, 07:02 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
If you look at the heat pattern on the pressure plate, it must have high spots...it is no good IMO
After you bolt up the flywheel, borrow a dial indicator to check to see if the flywheel face is running true. I just did a chatter job on a SBC that had a slightly bent crank.
If you can't borrow an indicator;
Just make some sort of hefty steel Z bracket bolted to the block and just about touching the face. Then keep checking the gap with feeler gauges as you rotate the flywheel a little at a time. It's crude but it will work.
Old 11-04-2008, 08:05 PM
88lowrider's Avatar
Helmar
Last journal entry: Engine
Flywheel , clutch and pressure plate.
Well, I would have the flywheel ground and then replace the clutch, pressure plate and throwout bearing. Oh, pilot bushing or bearing too.
If any cracking on the flywheel, use it to make a stand out of it to hold up your grinder or something. I have seen pictures when they explode.
Like some of the other say, check to assure nothing noticeably loose to let the drive train move around.
Might just get her up on a rack/lift and use a crow bar to see if anything is loose.
Its been awhile since I have checked but on GM, I found it was less expensive to buy a New Clutch and pressure plate from the GM dealer.
Might just make the phone call.
I used to keep the 11" clutch and pressure plate part numbers in my old Motors Manual.
Really, it could have been a bunch of simple reasons it started slipping, chattering. Anything to being driven though a large puddle to over greasing the throwout bearing and getting a taste of grease on them.
I would just shake it down with the crow bar and put her back together right. You sure as hell don't want this to come back on you. No one wants a crap job so do it right.
Just my opinion.
HJ
Old 11-04-2008, 10:03 PM
Years ago, in my Nova, I installed a "new" rebuilt clutch disc that chattered like all getout. I took it back and got another one and it did the same. I figured the springs in the hub section were weak. A new GM disc cured the problem.
Old 11-04-2008, 10:21 PM
88lowrider's Avatar
Helmar
I agree with you on the clutch disc.
That could have been the problem from the start, you never know.
HJ
Acceptable flywheel runout for 350 sbc..clutch chatter.. F&J Transmission - Rearend 13 04-08-2012 12:08 PM
Clutch Chatter super_silent Transmission - Rearend 5 09-18-2006 08:44 PM
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 04:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 10:26 PM
Clutch chatter zman48 Transmission - Rearend 5 10-13-2003 01:02 PM
