Fixing loose GM steering column - what bolt torque?
The tilt column in my '75 GMC was loose and I've broken it down enough to remove the four screws that hold the tilt mechanism on. I cleaned them, added lock tite, and screwed them back in with a 1/4" drive torque wrench.
I tightened the bolts by feel, and was careful to not get carried away (I probably have them at about 40 inch lbs right now. However, now I need to know the right torque. One book mentioned about 35 inch lbs, but I'm not sure they are talking about the right bolts. Update - just found one online reference that said 88 inch lbs. I tried that with the torque wrench and it feels about right for that size bolt. Anyone know the right torque for these bolts? I assume its relatively low torque, since they are small bolts. Thanks, Bruce Last edited by 75gmck25; 02-05-2012 at 09:46 AM. |
I tightened mine using German torque specs:
Good n tite. |
| Loose Steering Column With a Werid Twist | seawolf18 | General Rodding Tech | 5 | 09-15-2011 04:48 AM |
| Loose steering wheel on GM tilt column, how to fix ?? | NASCAR314 | Suspension - Brakes - Steering | 17 | 01-11-2009 07:20 PM |
| Loose Tilt Column | dsmith1279 | General Rodding Tech | 3 | 07-22-2008 06:45 AM |
| Corvette steering column loose | woody51 | Suspension - Brakes - Steering | 4 | 01-28-2005 03:29 AM |
| loose steering | Slant3 | Suspension - Brakes - Steering | 9 | 09-04-2004 08:36 AM |
