Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fixing loose steering
Old 12-30-2012, 05:53 PM
51 styline 51 styline is offline
Yes, on the ground. Measure from the centre tread to centre tread at the front and rear of tire and at the same height front and rear. If it,s wider at front too much toe out. I would think 1/16 -1/8 out would be close. You can probably get proper spec on line.
