Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fixing loose steering
Old 12-30-2012, 07:32 PM
LATECH's Avatar
LATECH LATECH is offline
Incorrect toe in will feather edge the tires. You will be able to feel it by running your hand across the tread.In some cases its easy to see, especially if the toe has been out for a while.
Hearing that it is pulling left, could be a dragging brake as suggested.
Also a complete front end inspection, also as suggested should be performed.
Idler arm comes to mind here.
Fact is stranger than Fiction
