fixing pitted chrome? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2002, 02:57 PM
New Member
Question fixing pitted chrome?
how do you fix pitted chrome have it on hood emblems.if i could just fix the pits i would powder coat it with almost chrome and im sure they would be good to go.the pitting isn't horrible but its moderate.thanks.
Conner
Old 06-01-2002, 05:17 PM
Post
Chemical Strip and see if the pits are into the metal or just the plating. Then Rechrome. Sorry but there isn't much to do with chrome after it is damaged.
Old 06-03-2002, 05:51 PM
New Member
Red face
i figured that much just hopeing i had something to fall back on but thanks for the responce stang i needed the motive to reaize the truth
Old 06-03-2002, 06:07 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Conner, if its not that bad, just bead blast the crome off and paint or powder coat the emblems. With the right color it could look ultra tough. If your going to get it re-chromed most shops with take care of the pits and get it all smooth for you.
Faust
Old 06-03-2002, 06:12 PM
New Member
Post
yeah the almost chrome paint is a powder coat id say the emblems are on average pitted(side emblems)my front emblem i belive could survive your suggestion i'll more than likly give it a go around.thanks
Conner
Old 06-04-2002, 04:25 PM
Post
Eastwood has powder for coating that can be polished to like chrome. Chrome is going to be more brilliant of course but the coating is close. For less than a hundred bucks (less than a chrome job or having someone powder coat) you can get a gun and some powder. The problem is, you need infrared lights to bake the powder because your bumper isn't going to fit into an electric oven. So you are stuck with taking it somewhere no matter what. Call and see what a strip and chrome will cost and what a strip and powder coat will cost and compare. After both procedures, they will have to polish the finish so you won't save money thinking that not having to polish will save. I took the bumper off a truck and had it chromed once. I opted for the better job that they offered and it came out better than new and the finish stayed longer, it took a week or so however. Good luck
need help on wiki article: pitted rust Jon Body - Exterior 4 08-07-2007 09:38 AM
removing/painting over chrome that is pot metal? 72helpneeded Body - Exterior 7 05-27-2006 09:09 PM
Painting chrome wp442 Body - Exterior 5 12-14-2003 10:35 AM
chrome paint? not painting chrome CustomChrome Body - Exterior 14 10-21-2003 08:44 PM
Fixing chrome trim Prock Body - Exterior 2 05-01-2002 03:39 PM
