Does anyone know where I can get some flag style connectors for 12/10 wire? I only need three to connect at my fuse panel to avoid kinking the main power wires. I,ve looked everywhere around the Detroit area,( the motor city; yeah right lol )
They are 90 degree connectors. The 12 ga. wire will come straight to the fuse panel then the spade is 90 degrees ( all one piece). I really don't want to make that turn with the wire itself.
IF your referring to "Trailer Type Fittings" , the type where you place one wire in, then the other in parallel, and crimp it down..DON"T use them ..Especially on a BUSS wire..
They short out, make intermittent or no connections, and fall apart..There is a reason you can't find them..
The Proper way to join those wires is SOLDER, cover with 2 sections of heat shrink tube, and secure with a rubber coated adel clamp.
He's looking for those uncommon 90* push-on terminals, sort of like that were used on sealed beam sockets (but those are bigger) Edit: I was typing as the above post was put up.
About the only links that get my attention nowadays, come with BBQ Sauce, Mustard, relish, Pickel, Cooked Slowly over Smokey hickory Chips in a smoker..Served on a paper plate.. :drool: :drool: :drool:
(Now only If I could eat and digest them ain: ...the smell is heaven enough..)
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
