Flahtead V8 Tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 09:33 AM
51FordDuff's Avatar
Flahtead V8 Tranny
Does anyone know of a floor shifter that will work on a stock 51 flathead transmission 3 speed the car did have overdrive but i don't know if it will have overdrive because im changing the car to 12v and i have no idea if they make the parts for it in 12 volts. the tranny was a column shift but i am going to be getting a new mustang 2 front end and i have no idea if the stock steering column will work with all of the new parts
Old 01-22-2006, 03:45 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
The elec OD stuff was used up through at least '67 on Ford Fairlanes. Parts aren't cheap. Just reduce your OD pwer supply to 6 volts.
Tranny update/Torque converter question RObs71Nova Transmission - Rearend 5 12-16-2004 09:37 AM
Ever have this happen to your tranny? Help BudLight Transmission - Rearend 6 06-12-2004 09:21 AM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 09:46 AM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
