Flakes In Clear - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2005, 08:18 AM
New Member
Flakes In Clear
Does anyone have pics of thier car w/a paint job using pearl flakes mixed in w/the clear? I want to see how it looks. I want it to be a pretty dramatic difference in sunlight. I am going candy apple red w/gold flakes. Is mixing the flakes in w/the clear the best method to see a good colorshift in sun? Also what would laying down a base of gold before the red do? I was told that may help also.
Old 06-19-2005, 11:02 AM
I have to tell you guy, you have a lot of work to do. Buy some candy, some flake, and a few different bases and SPRAY IT. Get a thrown away fender at a local body shop and mask it off in sections and using as many different techniques as you can SPRAY IT .
There is NO computer monitor that is going to give you any idea of what this stuff will look like out in the sun with your own eyes.
First off let me say I am no custom painter, there are some who visit this forum and they may have more direct answers for you, I don't know. But I have shot enough custom paint to know, the base MAKES your candy color. Sure a gold may look good under the candy, but it may not be what you want. Have you seen the HOK chip book? There are samples there of the different candies (Kandies) over different bases. The different bases WILL produce a pretty dramatic difference in the final color.
If you want a REAL flaky look, you would apply a very flaky base as well.
If you want flake over the candy, it is usually applied in a first coat of clear then clear without any flake is applied over that for the most dramatic effect. PLUS, you can't have flake in the final coat if you plan on cutting and buffing it because you will expose flakes when the chear is sanded.
My suggestion is to SPRAY IT OUT! One of the funest things with custom paint is to see the different effects from just a slightly different technique.
Old 06-19-2005, 11:51 AM
Last journal entry: metal finish
There is no need to put gold flake over a candy job.. if its real candy and u want bigger flakes then put it under the candy.. if its not a real candy that u are shooting and just a metallic or pearl red then put it over them if you want.. but there is no need for it over top of the candy... candy red from some angles throws off a goldish color....heres an m-coupe i painted candy red with a silver base and it still throws off a little gold.
Old 06-19-2005, 12:34 PM
speedfreak2's Avatar
WrenchingAce
I am NOT a body and paint guy but this is what happened to me...I wanted my car to be white with Cherry red metallic stripes. I also wanted a lot of "pop" in the paint so when I had it painted I put gold flake in the clear. Well, it turned my stripes from cherry red to a rust color. It still looks good but I really wanted cherry red. If I could do it over I would definitly leave the gold flake out.
Old 06-19-2005, 12:54 PM
Like I said, I am no custom painter, but I have seen many cars with flake in the clear over the candy. It really depends on what the owner wants, what "effect" is he after?
Now, as I said there is no way you can see what a particular effect is going to look like in person by seeing it on a computer monitor. Beembubya, as far as I can see on my HP monitor viewing over AOL I couldn't tell if that is the most beautiful, vibrant candy or a simple single stage OMNI! I have seen enough paint to be pretty sure it is a candy, but I certainly can't tell by that photo sitting on my monitor the quality of the application or vibrance of the color.
Old 06-19-2005, 02:23 PM
HAHA, yeah. but on my monitor looks like it has a gold shien to it.. ur def right on the monitor not showing the right color... joeguz your best bet is to experiment.. first thing i would do is spray a gold base (hok zenith gold if using hok) then mix the flakes into some intercoat clear shoot a coat or two then spray ur kandy then clear.. flake on top is going to kill the while kandy job.
Old 06-19-2005, 03:14 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
no substitute for seeing it in person thats correct but i can see the gold popping out on my monitor unless i missed the point LOL
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 06-19-2005, 05:47 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
I see the gold too, must be Brians eye's...LOL At his age these things start to fail along with many other things
Matthew
Old 06-19-2005, 09:28 PM
Rob Keller's Avatar
Wiki Edits: 38
i have a brand new 19"LCD monitor that might make a diff.?
sr66
"SlowRide66"
Old 06-19-2005, 10:09 PM
I've seen a red candy done with a silver base then the first coat of candy had some pearl mixed in then straight candy over that then cleared and it did look really nice. I have no idea what pearl was used but this was car was done back in the late 70's in laquer and it was really nice. The pearl within the candy did add more glow. Lots of different ways to do this stuff, test, test, and test till you get what you're after. If you're after the big flake look get ready to apply a lot of material- they are a challenge to bury.
Old 06-20-2005, 05:23 PM
mrcleanr6's Avatar
listen to everyone so far. do your tests but what i can tell you is any time you put something on top of a candy you lose that depth. if you put the gold under the candy it will look basically red. i attached a pic of a harley tank i did in candy red. its a coarse grain silver base. all the airbrushing is in white and black. you can see that once the candy goes on everything just turns a different shade of red. you will lose the gold effect and your pearl will blend right into the background. the depth is still there though and it looks good. the pearl on top is going to kill it!!! you want pop then put a metalflake instead of a pearl on under the candy, imo this will look much better.
ID:	5477   Click image for larger version
Old 06-20-2005, 09:23 PM
Have Gun, Will Paint
This car has red and gold flaked under, in and over some red candy........also the paterns ar inbetween a coat of candy.........all over a dark red base. http://www.cardomain.com/ride/469748
(we were drunk, some mistakes were made.....an attemped of currecting those mistakes led to the cars finish)
Clear, No Clear, or Clear + Base? tallpaul Body - Exterior 16 01-21-2006 06:30 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 03:52 PM
base coat clear coat wally Body - Exterior 8 12-12-2005 07:44 PM
New Paint, Clear Scratches real easy?? syclone477 Body - Exterior 11 03-20-2005 09:08 PM
Painting and Clear with PPG, what do I do next?????? harrija5 Body - Exterior 16 02-03-2005 09:50 PM
