flaking patches on bonnet and back 3/4 panel/blend issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2011, 03:25 PM
Marty7n's Avatar
Last journal entry: Lancer face lift
Hi i have patches of flaking paint on my project car.
- the bonnet has a big round patch,i have picked off all flaking paint
- same on the back left 3/4 panel and boot!
i was looking for some info on how to smooth and blend it in with the existing paint work to do a full respray eventually in the near future
after the above i will try fix the two dents on the front left door and back left door but thats for another day!
All help apreciated
what sand paper would i need?i was thinking maybe 300m or 500m not sure really!!
Old 03-22-2011, 08:01 PM
mean s15
flaking paint
To me it sounds like adhesive problem. You might be trying too blend too far. Did you sand past the area that you want to blend? If it ain't scuffin it ain't stickin therefore its flaking back off.
Old 03-23-2011, 06:06 AM
Old Fool's Avatar
More details are needed, just what is flaking? Is it the primer from the metal, the base from the primer, the clear from the base? how was it prepared, what materials were used, etc.
Old 03-23-2011, 11:14 PM
Rag top bird's Avatar
Hot rods are still the king
First I would clean the panel with a good wax and grease remover then water block the edges with 400 grit wet or dry sandpaper until the edges or gone then apply 2 coats of 2K primer then water block with 600 grit then you should be ready to paint
Old 03-24-2011, 07:03 AM
302 Z28's Avatar
If you have true flaking, paint separating from primer then you may be chasing your tail. You may have an adhesion problem and any repair may be only temporary.
Vince
Old 03-27-2011, 05:04 PM
Marty7n's Avatar
yes thats exactly the solution i was looking for Rag top bird,i have bought a gallon of quick line panel wipe!will the panel wipe degrease?i have 2 sheets of 600 and 1200,picked up 4 red 3M scotch pads also to help degrease the whole car as i plan to paint the whole car as the factory paint job has came up in patches,like i mean all the way to the metal!no rust,just a small tiny dry bit of base coat left on the steel in the patches where the paint has flaked off with age!
Old 03-28-2011, 03:24 PM
Marty7n's Avatar
Vince
would it have anything got to do with it been the factory paint on a 96 mitsubishi?
Old 03-28-2011, 03:39 PM
mean s15
flaking paint
It's mopar factory paint, true fact any dodge (mitsubishi) i have seen has had paint issues,might just need to strip it clean and put a new paint job with good paint, like dupont. Or else like 302 z28 said, you will be chasing your tail.
Old 04-05-2011, 03:55 PM
Marty7n's Avatar
its terrible paint,its flaking badly so iv decided to sand the whole car and respray it metallic grey or gunmetal grey!iv removed front bumper,all headlights,window trims,mirrors,door handles,mud guards,spoiler and original mitsi signs,so far iv sanded the bonnet,two wings,driver and passenger doors,half the roof,so halfway their,will get pictures up of the car sanded and start a project thread on this if its possible here??anyone know??
Old 04-05-2011, 04:05 PM
mean s15
I'm new here too but I'm sure you can start a project journal.
Old 04-11-2011, 07:14 PM
Marty7n's Avatar
have posted lancer project journal all is welcome to look and comment on it tnx!!!
Having issues with back lights on 96 chevy s10. eric32 Electrical 17 06-19-2009 06:18 PM
removing back panel? shadowismydogsname Body - Exterior 3 04-16-2008 07:45 AM
My back issues. DoubleVision Hotrodders' Lounge 9 08-23-2007 02:34 AM
Car Magazine back issues Larry3 General Rodding Tech 2 06-30-2006 09:54 AM
Back Fire Issues AndyB Engine 24 01-30-2005 10:10 AM
