Steve, you could use some DBU500 midcoat intercoat clear and mix in the amount of basecoat and any pearl that is needed, the intercoat clear mixes and sprays the same as basecoat and will need to be clearcoated. Go to PPG's website and print off the tech sheets for all products you're using. Scuff the panel down then mask off your flames and apply your transparent mix over the flames, unmask then clear the complete panel. You might want to spray a black test panel then apply your transparent mixture over it to verify it's what you want before respraying the flames. Bob
Thanks for the advice Bob. That's a good idea about the black test panel. After spraying a test panel then I can adjust the mixture accordingly to give me the desired look, correct? What kind of effect will the pearl give me? The DBU base that I am using already has some pearl and metalic mixed into the base.
| My work in progress custom dash: advice needed. | friday | General Rodding Tech | 6 | 12-31-2010 01:20 PM |
| turbo advice needed | segge | Hotrodders' Lounge | 1 | 05-09-2005 03:07 PM |
| Body Shop - Advice needed | beyondhelp | Hotrodders' Lounge | 8 | 12-09-2004 06:04 AM |
| expert advice needed.... | sglig | Interior | 8 | 03-31-2003 07:22 AM |
| AC advice needed | WayOutCat | Hotrodders' Lounge | 3 | 09-19-2002 08:50 PM |
